Topic: PROGMEM in the Arduino 1.0.1 IDE (Read 2730 times) previous topic - next topic
tocpcs
I'm utilising the ODBuino project here, http://code.google.com/p/opengauge/source/browse/trunk/obduino32K/obduino32K.pde
To rewrite to use it for a similar but different protocol purpose.
I know the code for that compiles fine on Arduino 0022 as I did have it working there previously.
The compiler in 1.0.1 is throwing a heap of errors mainly due to the PROGMEM prog_char deprecation that's occurred.
I've gone through and modified the lines such as line 759:
prog_char pctd[] PROGMEM="- %d + "; // used in a couple of place
Becomes:
const char pctd[] PROGMEM = "- %d + "; // used in a couple of place
I get problems like this:
prog_char select_no[]  PROGMEM="(NO) YES "; // for config menu
prog_char select_yes[] PROGMEM=" NO (YES)"; // for config menu
Changed to:
const char select_no[]  PROGMEM = "(NO) YES "; // for config menu
const char select_yes[] PROGMEM = " NO (YES)"; // for config menu
Gives an error from function menu_select_yes_no, which is programmed as:
byte menu_select_yes_no(byte p)
 boolean exitMenu = false;
 // set value with left/right and set with middle
 exitMenu = delay_reset_button();  // make sure to clear button
 do
   if(LEFT_BUTTON_PRESSED)
     p=0;
   else if(RIGHT_BUTTON_PRESSED)
     p=1;
   else if(MIDDLE_BUTTON_PRESSED)
     exitMenu = true;
   lcd.setCursor(4,1);
   if(p==0)
     lcd_print_P(select_no);
     lcd_print_P(select_yes);
   exitMenu |= delay_reset_button();
 while(!MIDDLE_BUTTON_PRESSED && !exitMenu);
 return p;
The error given is 'invalid conversion from const char* to char*' - this would relate to the lcd_print_P line, which takes the const char "select_yes" and prints to LCD.
void lcd_print_P(char *string)
 char c;
 while( (c = pgm_read_byte(string++)) )
   lcd.write(c);
I think the problem is actually the code - lcd_print_P gets a ? pointer? to a string and needs to read it?
dc42
You need to change both instances of "void lcd_print_P(char *string)" to "void lcd_print_P(const char *string)". Which is how it should have been written in the first place.
tocpcs
That fixed the bulk of the errors, there's still some errors hanging around.
'error: cannot convert 'const char*[15]' to 'const char **' for argument to 'byte menu_selection(const char**, byte)'
The function is used to display a menu produced from an array:
Line 3322: byte menu_selection(char ** menu, byte arraySize)
I'm using it as below:
byte menu_selection(const char ** menu, byte arraySize)
  byte selection = 1; // Menu title takes up the first string in the list so skip it
  byte screenChars = 0;  // Characters currently sent to screen
  byte menuItem = 0;     // Menu items past current selection
  boolean forceExit = false;
  // Note: values are changed with left/right and set with middle
  // Default selection is always the first selection, which should be 'Exit'
  lcd.clear();
  lcd.print((char *)pgm_read_word(&(menu[0])));
  forceExit = delay_reset_button();  // make sure to clear button
The array being passed in is as below:
const char displayMenu[6][13] PROGMEM = {"Display menu", "Exit", "Contrast", "Metric", "Fuel/Hour", "Font"};
const char adjustMenu[11][12] PROGMEM = {"Adjust menu", "Exit", "Tank Size", "Fuel Cost", "Fuel %", "Speed %", "Out Wait", "Trip Wait", "Tank Used", "Tank Dist", "Eng Disp"};
They were defined as:
prog_char *adjustMenu[] PROGMEM = {"Adjust menu", "Exit", "Tank Size", "Fuel Cost", "Fuel %", "Speed %", "Out Wait", "Trip Wait", "Tank Used", "Tank Dist", "Eng Disp", };
dc42
#3
Jan 06, 2013, 11:56 am Last Edit: Jan 06, 2013, 11:59 am by dc42 Reason: 1
You appear to be using a mixture of 2-dimensional char arrays, and arrays of char pointers. These are not the same. The 2D array form wastes space by padding out all the strings to the size of the biggest one. I suggest you use arrays of char pointer throughout. Define them like this:
const char *adjustMenu[] PROGMEM = {"Adjust menu", "Exit", "Tank Size", "Fuel Cost", "Fuel %", "Speed %", "Out Wait", "Trip Wait", "Tank Used", "Tank Dist", "Eng Disp", };
When you declare functions that take them as parameters, declare the parameter type as "const char **" or "const char*[]".
EDIT: even better, use "const char* const adjustMenu[] PROGMEM" and "const char* const*" or "const char* const[]".
