Topic: Dummy load on ATX power supply (Read 966 times) previous topic - next topic
Voidugu
I'll get straight into the question:
Do i need to have a dummy load connected on an ATX power supply if it is going to be used as a bench power supply?
Why is this dummy load needed?
What happens if i do not connect it?
Will it harm the power supply if it is used without the load?
Thank you very much in advance
Best Regards
Dima
dhenry
Many of them need to have some load current to work.
I put a small 12v lamp there.
Voidugu
Could you please answer the other questions as well?
mauried
ATX supply needs a minimum load on its output to regulate.
If you dont have a load, the output voltages will rise above their nominal values.
Depending on what the switcher chip in the supply is , the supply can shut itself down
if the output voltage goes high.
Depending on the power rating of the supply, you will have to experiment to find out what
minimum load is needed.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
