Loading...
Pages: 1 [2]   Go Down
Author Topic: Nikolausi / Werbung in eigener Sache  (Read 1215 times)
Hamburg, Germany
Offline Offline
Full Member
Hello world!
View Profile
WWW
Jaaa, ein neues Spielzeug smiley Dankeschön smiley
Logged
Hamburg, Germany
Offline Offline
Full Member
Hello world!
View Profile
WWW
Heute angekommen und echt cool smiley
Ich hab' einen online POV-Generator geschrieben (http://test.sui.li/blinkenlightpov/) und so sieht's aus:
+Sketch für Arduino Mega (weil ich gerade kein Uno/Duemilanove da hatte...)
Code:
#include <avr/io.h>
#include <avr/pgmspace.h>
uint8_t pov_pattern[] PROGMEM = {
  0b000001, 0b111000, 0b00000000,
  0b000111, 0b111110, 0b00000011,
  0b001111, 0b001111, 0b00001010,
  0b011100, 0b000011, 0b10000111,
  0b011000, 0b000001, 0b10000000,
  0b111000, 0b110001, 0b11001111,
  0b110000, 0b110000, 0b11001010,
  0b110000, 0b110000, 0b11001111,
  0b111000, 0b110001, 0b11000000,
  0b011000, 0b000001, 0b10001111,
  0b011000, 0b000011, 0b10001001,
  0b011100, 0b000111, 0b00001110,
  0b001111, 0b001111, 0b00000000,
  0b000111, 0b111110, 0b00001111,
  0b000011, 0b111000, 0b00000001,
  0b001100, 0b000111, 0b00001001,
  0b011100, 0b000011, 0b10001111,
  0b011000, 0b000001, 0b10001001,
  0b110001, 0b111000, 0b11001111,
  0b110000, 0b110000, 0b11000100,
  0b001111, 0b001111, 0b00001001,
  0b000111, 0b111110, 0b00001110,
  0b000000, 0b000000, 0b00000000,
static uint16_t index = 0;
uint8_t leds[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,54,55,56,57,58,59};
byte b1 = pgm_read_byte(pov_pattern+(index++));
byte b2 = pgm_read_byte(pov_pattern+(index++));
byte b3 = pgm_read_byte(pov_pattern+(index++));
        if (b1 & 0b100000) { led(0,1); } else { led(0,0); }
        if (b1 & 0b010000) { led(1,1); } else { led(1,0); }
        if (b1 & 0b001000) { led(2,1); } else { led(2,0); }
        if (b1 & 0b000100) { led(3,1); } else { led(3,0); }
        if (b1 & 0b000010) { led(4,1); } else { led(4,0); }
        if (b1 & 0b000001) { led(5,1); } else { led(5,0); }
        if (b2 & 0b100000) { led(6,1); } else { led(6,0); }
        if (b2 & 0b010000) { led(7,1); } else { led(7,0); }
        if (b2 & 0b001000) { led(8,1); } else { led(8,0); }
        if (b2 & 0b000100) { led(9,1); } else { led(9,0); }
        if (b2 & 0b000010) { led(10,1); } else { led(10,0); }
        if (b2 & 0b000001) { led(11,1); } else { led(11,0); }
        if (b3 & 0b10000000) { led(12,1); } else { led(12,0); }
        if (b3 & 0b01000000) { led(13,1); } else { led(13,0); }
        if (b3 & 0b00100000) { led(14,1); } else { led(14,0); }
        if (b3 & 0b00010000) { led(15,1); } else { led(15,0); }
        if (b3 & 0b00001000) { led(16,1); } else { led(16,0); }
        if (b3 & 0b00000100) { led(17,1); } else { led(17,0); }
        if (b3 & 0b00000010) { led(18,1); } else { led(18,0); }
        if (b3 & 0b00000001) { led(19,1); } else { led(19,0); }
        delay(10);
        if (index >= sizeof(pov_pattern)) { index = 0; delay(40); }
void led(int no, int st) {
  digitalWrite(leds[no], st);
     for (int i = 0; i< sizeof(leds); i++) {
       pinMode(leds[i], OUTPUT);
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
Ja, als ich das Teil entwickelt hatte war es nur eine "billige Spielerei". Bis mir aufgefallen ist, daß das sehr viel cooler als eine abgesetzte LED Zeile ist smiley
Freut mich daß es Dir auch gefällt smiley
Den Sketch hast Du ja gut hinbekommen.
Logged
Check out my experiments http://blog.blinkenlight.net
NRW
Offline Offline
Sr. Member
View Profile
Meins ist auch Heute angekommen!
Toller Karton und natürlich auch tolles Shield.
Ich denke mal morgen mache ich mich mal ran was dafür zu schreiben.
Danke Udo
Logged
NRW
Offline Offline
Sr. Member
View Profile
Test 1.2.3.
Hab erstmal geschaut ob alles funktioniert!
Dafür habe ich mal den Code von sui geklaut und den POV-Generator:
« Last Edit: January 04, 2013, 02:51:32 am by MueThoS » Logged
Offline Offline
Edison Member
View Profile
Na toll, mit meinem spielt bestimmt gerade ein Postbote  smiley-cry
Logged
NRW
Offline Offline
Sr. Member
View Profile
So, ich bin ja kein guter Programmierer wollte aber auch eine Möglichkeit haben Patterns zu erstellen.
Tja in was schreiben wenn man nix vernünftig kann?
Excel kann ich ganz gut.
Na dann los:
Ein Editor in dem man mit Doppelklick Punkte malen kann.
Man kann alles löschen so das alles aus ist oder das alles an ist.
Man kann einen Bereich markieren der wird negiert. Also alles was schwarz war wird weiss und umgekehrt.
Und man kann den Bereich festlegen der in den Code umgewandelt wird. (doppelte Linien).
Dann noch auswählen in welche Richtung man wischen will und Code generieren.
Hier hat man dann die Möglichkeit den Code in die Zwischenablage zu kopieren.
Und man kann noch den Code der vor dem Pattern und nach dem Pattern ist ändern.
Jetzt kann ich wenigstens schon mal was malen
Zugegeben der Arduino-Code ist noch der vom sui
Logged
AREA COLOGNE
Offline Offline
God Member
I am 1 of 10 who understands binary
View Profile
WWW
Scheint das ich den gleichen Postboten habe wie mkl0815
Logged
Eine Glatze ist wohl die AUSGEFALLENste Frisur von allen.
Offline Offline
Edison Member
View Profile
So, Shield ist heute angekommen. Vielen Dank nochmal. Ein erster Funktionstest war erfolgreich. Zu mehr komme ich aber erstmal nicht, da mein eigenes LED Projekt erstmal fertig werden muss. Die kleine Versandverzögerung hatte also durchaus was positives, hab ich doch mein Spaghetti-Arduino Board heute Nacht final zum laufen gebracht :-)
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
