Topic: Help if/else (Read 600 times) previous topic - next topic
afonsus
I dont understand why this is not working!
it says else withou previous if
Code: [Select]
int led1 = 13;
int led2 = 12;
int led3 = 11;
int led4 = 10;
int led5 = 9;
int switchPin = 7;
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(switchPin, INPUT);
  if (digitalRead(switchPin) == HIGH);
    goto knightRider;
    digitalWrite(led1, HIGH);
    digitalWrite(led2, HIGH);
    digitalWrite(led3, HIGH);
    digitalWrite(led4, HIGH);
    digitalWrite(led5, HIGH);
knightRaider:
  delay(100);
  digitalWrite(led1, LOW);
  delay(100);
  digitalWrite(led2, LOW);
  delay(100);
  digitalWrite(led3, LOW);
  delay(100);
  digitalWrite(led4, LOW);
  delay(100);
  digitalWrite(led5, LOW);
  delay(100);
  delay(100);
  delay(100);
AWOL
#1
Jan 05, 2013, 03:49 pm Last Edit: Jan 05, 2013, 03:52 pm by AWOL Reason: 1
Code: [Select]
Lose the semicolon.
Then lose the goto.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
tobyb121
the "goto" instruction is generally frowned upon in high level languages (anything above assembly code really) as it causes alot of problems, particularly for beginners, because of code readability, and sometimes causes unexpected errors. For this kind of code you should use a function call:
Code: [Select]
       knightRider();
    //do something else
void knightRaider()
    //Stuff here
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
