Loading...
Pages: [1] 2   Go Down
Author Topic: Zener Diode not Zenering at all ;-( ...  (Read 596 times)
London
Offline Offline
Full Member
Arduino has it all
View Profile
WWW
I am designing a circuit with some expensive components ($60.0 plus) and I wanted to protect them from voltage spikes with Zener diode. So I took this Vishay BZX55C4V3 Zener Diode and connected it to 120 Ohm resistor and connected it to a power supply and oscilloscope.
First, as I understand, this Zener is supposed to keep voltage across itself fixed at 4.3V. But if I rump up the power supply to 10 or 11V I can push Zener to about 4.8V. So, no protection there.
Second, I have a neon lamp (one with magnifying glass) directly above my desk and above the circuit itself. Maybe 10"(25cm). If I turn on the lamp, I can see on the oscilloscope that voltage spikes up, across the diode itself, to 5.6V. Granted, this can be induction in the oscilloscope cable. Again, no protection from inductive spikes.
So what it is wrong here? It seems that these Zener diodes are neither regulating voltage from power supply, neither protecting from EMF in the environment.
How can I properly protect the circuit from voltage spikes? Is there a rock solid way to get specified voltage protection?
« Last Edit: January 05, 2013, 08:43:12 am by DROBNJAK » Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
The simplest way to protect an input against overvoltage is a simple series resistor. The best value for the resistor depends on what voltage you need to protect against, and the function of the input.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
London
Offline Offline
Full Member
Arduino has it all
View Profile
WWW
Hmnm, adding the resistor in series is only going to dampen the spike, not remove it. I tried, just now, covering the cables with aluminum foil. No avail either.
Logged
Offline Offline
Edison Member
View Profile
Quote
You are expecting the zener to do something it isn't designed to do.
The issue isn't the zener. It is your expectation of the zener.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
What the resistor does is to limit the current into the pin to a safe value that the internal pin protection diode can safely cope with.
Logged
London
Offline Offline
Full Member
Arduino has it all
View Profile
WWW
OK, but is there a way to just 100% solid limit the voltage to a desired value? So whenever a spike happens, the component just shaves it off clean.
I mean, all the tutorials on the web are talking about Zener diodes regulating voltage. When in reality they are quite loose. On this one that was rated 4.3V, it can go all the way to 5.0V and even higher.
« Last Edit: January 05, 2013, 10:04:32 am by DROBNJAK » Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Yes, use a silicon diode or Schottky diode between the signal and a power supply with a voltage just below the desired limit voltage, with a capacitor across the supply to absorb the energy. That is how the pin protection diodes work.
Logged
London
Offline Offline
Full Member
Arduino has it all
View Profile
WWW
Many thanks. I'll try that. I've just tried the above lamp trick on L78M09CV 9.0V Voltage Regulator and it didn't glitch at all. No spikes whatsoever. No wander one always see these things on all the Arduino breakout boards ;-). So that's the way to go. Maybe I'll use Zeners for something else.
What is really the real use for Zener diodes, if they are quite loose as voltage regulators?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
As you have discovered it is a wast of time doing that. Even proper shielded cable doesn't act like you expect.
What is wrong is your expectations and supposed requirements for protection.
There is a balance between low impedance and effective suppression. The better the suppression the higher is the input impedance.
The ultimate is to add a buffer on the front end, rather than just putting a signal into an expensive chip.
Logged
London
Offline Offline
Full Member
Arduino has it all
View Profile
WWW
@Grumpy_Mike
Yeah, that was what I thought Zener will do. Sorry for my newbie's ignorance, what would be a good buffer in this case?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Well you haven't said what the signal or the component is but if it is a logic level signal then something like a 74LS04 or even a simple transistor will isolate anything picked up on the line from the chip.
Logged
Offline Offline
Edison Member
View Profile
Quote
Depends on your definition of "clean". Most diodes or zvs or zeners allow some degree of variations above their rated levels, more or less.
Quote
That's how they are.
A "cleaner" solution would be a voltage reference, like tl431. However, those devices have limited ability to absorb shocks (fast / large transients).
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Quote
I had a similar issue and found that zeners require a certain minimum current flowing thru them to function as a voltage limiter (check the data sheet for your zener). You might try six .7v voltage drop diodes in series to limit the board voltage to 4.2v.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Brattain Member
View Profile
WWW
Protection with diodes can be a complex matter. There is a good data sheet about the TPD2EUSB30 that goes into many of the issues.
Logged
Offline Offline
Sr. Member
View Profile
Quote
Look at the datasheet again.... and don't overlook the definition of minimum, nominal, and maximum.
And don't forget how temperature may affect that too. look at the graphs.
You want something that regulates, put a proper 3-terminal voltage regulator there, and adjust it to whatever value you want.
Quote
It's more of a voltage clamping device, not a "proper" voltage regulator.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
