Loading...
Pages: [1]   Go Down
Author Topic: Create variable directory and incremetal files  (Read 601 times)
Italy
Offline Offline
Newbie
View Profile
Hello everybody!
I'm doing a project where i need to collect data from sensors and then save these data in a SD card memory; all these things are well explained in Arduino's reference guide on the website but I however found a trouble: since in my project i collect the temperature and other parameters per each day, I also need to collect them in order into the SD, making a txt file per each day. it would be beautiful if I can also make a folder for each year, with a folder for each month in it, like this: 2013/jan,feb,mar,apr,may,jun..etc and for each month 31 or 30 files(one per day).
The trouble is that in the code line for writing a directory and also for making files, you must write only const char : SD.mkdir("a/b/c") in this i'll have only three folders;  SD.open("*.txt")
My question is: how I can use for example a for loop for increasing (for example an array, year[X]), for creating a new directory every year, and the same for month of course?
thanks for answering, and if this topic had already been treated, can you send me to that page?
thanks a lot.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
That is not true. You can create any number of directory levels at once, using a dynamically defined string.
Code:
int year = 2013;
char dirName[24];
sprintf(dirName, "%d/Jan", year);
SD.mkdir((const char *)dirName);
should create a directory called Jan in one called 2013.
Quote
Why would year be an array? In the snippet about, you can increment year by 1 and get 2014/Jan created.
You could create an array of month names:
char monthNames[] = {"", "Jan", "Feb", "Mar", "Apr", ...
Then:
Code:
int month = 3;
sprintf(dirName, "%d/%s", year, monthNames[month]);
should create a directory called Mar in one called 2013.
Logged
Italy
Offline Offline
Newbie
View Profile
@PaulS:
Thank you very much for the help, and I'm sorry for having written false things but I really didn't know that kind of code, I studied it at high school (C++), but not in a close way, so I really thank you for help, this will allow me to finish my project and do more complex project in future!
Logged
Italy
Offline Offline
Newbie
View Profile
@PaulS
Hi and thanks again for the help, I have other questions:
when i compile the code line you have given to me, at:   char monthNames[] = {"", "Jan", "Feb", "Mar", "Apr"}; the compiler says:
error: too many initializers for 'char []'
and for: SD.mkdir((const char *)dirName);  error: invalid conversion from 'const char*' to 'char*'
then I don't know if there are other errors
I put this code lines in a program just to try..
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
should have been:
Code:
char *monthNames[] = {"", "Jan", "Feb", "Mar", "Apr"}; the compiler says:
Quote
Then, the cast is not necessary.
Code:
SD.mkdir(dirName);
Logged
Italy
Offline Offline
Newbie
View Profile
@PaulS, hello, since you have been able to help me i ask again for your help, this time i would need to know how write a file into a directory I have created before. the trouble is I have created the directory and the file with the code lines you have shown me in messages before, but when I try to create the files in the directory, i fail.
my idea is: I create a directory that it can change when i decide to do that, and i would make a file per day, and then write on time every minute. Thanks again for your time!!
I post you the skecth:
#include <SD.h>
char dirName[8],DATO[18],fileName[8],DataString[20];
unsigned long ms=0, psd=0;
int anno=2014;
byte mese=1, giorno=2, ore=3, minu=4, sec=5;
File myFile;
void setup(){
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
  Serial.println("initialization done.");
void loop(){
  Serial.println("sd");
    sprintf(dirName, "%d/%d/%d.txt", anno,mese,giorno);  //per creare la directory
    //SD.mkdir(dirName);
    //sprintf(fileName,"%d.txt",giorno);// per creare il nome del file
    //sprintf(DATO,"%d/%d",dirName,fileName);//per creare la location dove scrivere il file
    sprintf(DataString,"%d/%d/%d  %d:%d:%d   ",giorno,mese,anno,ore,minu,sec);// crea la stringa da stampare su sd
    myFile = SD.open(dirName);
    myFile = SD.open(dirName, FILE_WRITE);
    myFile.println(DataString);
     if (myFile) {
     Serial.print("Writing to test.txt...");
     //myFile.print(T,1);
     //myFile.print(" , ");
     //myFile.print(H);
     //myFile.print(P);
     //myFile.println(A);
        // close the file:
     myFile.close();
     Serial.println("done.");
     // if the file didn't open, print an error:
     Serial.println("error opening test.txt");
    giorno++;
    ore++;
    minu++;
    sec++;
Logged
Pages: [1]   Go Up
Print
Jump to:
