Offline
Jr. Member
« on: January 05, 2013, 10:09:03 am » |
I have a arduino dumilanalov, which I'm using to re-bootload my Atmega168. I ran the atmega board detector script by Nick Gammon, http://www.gammon.com.au/forum/?id=11637, and got the following results. Atmega chip detector. Entered programming mode OK. Signature = 1E 94 06 Unrecogized signature. LFuse = FF HFuse = DF EFuse = F8 Lock byte = FC Clock calibration = 90
First 256 bytes of program memory:
0: 00 00 01 01 00 00 03 03 00 00 01 01 04 04 07 07 10: 00 00 01 01 00 00 03 03 08 08 09 09 0C 0C 0F 0F 20: 00 00 01 01 00 00 03 03 00 00 01 01 04 04 07 07 30: 10 10 11 11 10 10 13 13 18 18 19 19 1C 1C 1F 1F 40: 00 00 01 01 02 02 03 03 00 00 01 01 04 04 07 07 50: 00 00 01 01 00 00 03 03 08 08 09 09 0C 0C 0F 0F 60: 20 20 21 21 20 20 23 23 20 20 21 21 24 24 27 27 70: 30 30 31 31 30 30 33 33 38 38 39 39 3C 3C 3F 3F 80: 00 00 01 01 00 00 03 03 00 00 01 01 04 04 07 07 90: 00 00 01 01 00 00 03 03 08 08 09 09 0C 0C 0F 0F A0: 00 00 01 01 00 00 03 03 00 00 01 01 04 04 07 07 B0: 10 10 11 11 10 10 13 13 18 18 19 19 1C 1C 1F 1F C0: 40 40 41 41 40 40 43 43 40 40 41 41 44 44 47 47 D0: 40 40 41 41 40 40 43 43 48 48 49 49 4C 4C 4F 4F E0: 60 60 61 61 60 60 63 63 60 60 61 61 64 64 67 67 F0: 70 70 71 71 70 70 73 73 78 78 79 79 7C 7C 7F 7F
And when i proceeded to burn my bootloader using, atmega board programmer sketch, i got the following message. Atmega chip programmer. Written by Nick Gammon. Entered programming mode OK. Signature = 0x1E 0x94 0x06 Unrecogized signature. LFuse = 0xFF HFuse = 0xDF EFuse = 0xF8 Lock byte = 0xFC Clock calibration = 0x90 Type 'C' when ready to continue with another chip ...
Is my chip dead?
Logged
Windy City
Offline
Jr. Member
« Reply #1 on: January 05, 2013, 10:31:36 am » |
That looks like the right signature for a 168. Maybe Nick can help resolve this.
Logged
Dirt Biker
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #2 on: January 05, 2013, 10:52:10 am » |
Nick's program is looking for the following signature bytes to identify the chip as a mega168: { { 0x1E, 0x94, 0x0B }, "ATmega168PA", 16 * kb, 256, So maybe there are different 'flavors' of 168 chip. You might just try and edit nick's sketch for that line and see if will then attempt to load the bootloader: { { 0x1E, 0x94, 0x06 }, "ATmega168PA", 16 * kb, 256, Lefty
Logged
Offline
Jr. Member
« Reply #3 on: January 05, 2013, 12:47:29 pm » |
Thanks a lot retrolefty  THe bootloading worked.... But the chip, still wouldn't let me upload new programs. :/
Logged
Offline
Brattain Member
« Reply #4 on: January 05, 2013, 01:19:49 pm » |
Thanks a lot retrolefty  THe bootloading worked.... But the chip, still wouldn't let me upload new programs. :/ So what is your 168 based 'board', does it run the chip at the correct crystal speed? Does it support auto-reset that the IDE requires? Have you run a loopback test on your 168 based setup to see if your communication link works? Lefty
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #5 on: January 05, 2013, 03:42:46 pm » |
I didn't actually test that signature but added it for someone else.
The fact that you uploaded OK shows the chip is good. I can't remember right now which bootloader I used for that chip*, but the clock speed would need to match and you would need to select the correct bootloader in the IDE so that the protocol matches.
* Looks like it is optiboot_atmega168.hex
Logged
SF Bay Area (USA)
Online
Faraday Member
Strongly opinionated, but not official!
« Reply #6 on: January 05, 2013, 04:19:13 pm » |
Did you modify the boards.txt file and select the appropriate board type so that the IDE knows about the new connection speed used for uploads (and also the new space available?)
The ATmega168PA vs ATmega168 is like the 328P vs 328; the chips are very close to identical, but have different signatures. (The difference is that Arduino supports the 168 and 328P without effort, while the 168PA and 328 require hacking.) The 168 and 168PA can use the same bootloader, and once that happens the Arduino IDE will treat the chips exactly the same.
Nick's program (and Optiloader) are especially useful for putting bootloaders into these "odd signature" chips, because they have their own idea about the translation of signature to "matching" bootloader code.
Logged
Offline
Jr. Member
« Reply #7 on: January 06, 2013, 12:56:17 am » |
I actually have a duemilanove clone board, which i used to program both my atmega328P( selecting the 'arduino duemilanove w/ atmega328' board), and my Atmega168 (selecting the 'arduino diecimila or duemilanove w/ Atmega168). Both had bootloaders. And i haven't done the loopback test. Will it confirm if my chip is dead or working? Some time back, my 168 stopped working( always failed while programming it). After i read Nick Gammon's page, i thought i'd try re-uploading the bootloader. The fact that you uploaded OK shows the chip is good. I can't remember right now which bootloader I used for that chip*, but the clock speed would need to match and you would need to select the correct bootloader in the IDE so that the protocol matches. Thanks for your reply. I actually burned the bootloader after making the changes Retrolefty told in the above comments. I'm sorry i didn't really get, what you meant by select the correct bootloader in the IDE? Did you modify the boards.txt file and select the appropriate board type so that the IDE knows about the new connection speed used for uploads (and also the new space available?) Thanks for you reply. I haven't modified the file. What board should i be selecting?
Logged
SF Bay Area (USA)
Online
Faraday Member
« Reply #8 on: January 06, 2013, 02:35:51 am » |
What board should i be selecting? You need to either modify the Duemilanove w 168 entry (in which case you won't be able to program regular duemilanoves any more), or add a new entry: uno168.name=Arduino Uno168 - Any Arduino with ATmega168 CPU and Optiboot bootloader uno168.upload.protocol=arduino uno168.upload.maximum_size=15872 uno168.upload.speed=115200 uno168.bootloader.low_fuses=0xff uno168.bootloader.high_fuses=0xde uno168.bootloader.extended_fuses=0x05 uno168.bootloader.path=optiboot uno168.bootloader.file=optiboot_atmega168.hex uno168.bootloader.unlock_bits=0x3F uno168.bootloader.lock_bits=0x0F uno168.build.mcu=atmega168 uno168.build.f_cpu=16000000L uno168.build.core=arduino uno168.build.variant=standard
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #9 on: January 06, 2013, 03:10:17 pm » |
There are various uploading protocols, and also baud rates for uploading. When you select a board in the IDE it uses the relevant section of the boards.txt file to choose a protocol and baud rate. If you choose the wrong one, the wrong protocol/baud rate will be used and you will get some sort of error. You don't literally have to have the selected board, but the chip being programmed has to: - Have the bootloader that the board is "configured" for (eg. 32 Kb Optiboot)
- Be running at the clock speed that makes the baud rate correct
For example, I program a Duemilanove with "Uno" selected as the board type, because I uploaded the Uno "Optiboot" bootloader. What is written on the board doesn't count, it is the factors above. I also select Uno with "bare bones" (breadboard) chips once I put the Optiboot bootloader on them.
Logged
Offline
Jr. Member
« Reply #10 on: January 07, 2013, 11:16:51 am » |
Sorry for the late reply...
As Westfw, told, i added the entry to my boards.txt, but it isn't appearing in the boards menu in the IDE o.O. I'm attaching the boards.txt.
Logged
SF Bay Area (USA)
Online
Faraday Member
« Reply #11 on: January 08, 2013, 10:52:59 am » |
Did you restart the IDE? It only reads boards.txt at startup.
Logged
Offline
Jr. Member
« Reply #12 on: January 12, 2013, 01:57:25 am » |
Did you restart the IDE? It only reads boards.txt at startup. Yes. I did try restarting the IDE, it isn't coming in the menu.Is there anything wrong with my entry into the boards.txt?
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #13 on: January 12, 2013, 02:46:24 am » |
boards.txt (13.02 KB - downloaded 32 times.)
I get: Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1077305799
Varnish cache server However I can read other posts.
Logged
Offline
Jr. Member
« Reply #14 on: January 12, 2013, 03:37:34 am » |
I get:
Code: Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1077305799
Sorry about that..I've added a screenshot, if that doesn't help could you pm me your id. I'll mail it to you. There seems to be some problem while opening the boards.txt attachment. Not quite sure, why.
« Last Edit: January 12, 2013, 03:55:26 am by grimreaper »
Logged
