Loading...
Pages: [1]   Go Down
Author Topic: Dummy load on ATX power supply  (Read 312 times)
Offline Offline
Jr. Member
View Profile
I'll get straight into the question:
Do i need to have a dummy load connected on an ATX power supply if it is going to be used as a bench power supply?
Why is this dummy load needed?
What happens if i do not connect it?
Will it harm the power supply if it is used without the load?
Thank you very much in advance
Best Regards
Dima
Logged
Offline Offline
Edison Member
View Profile
Many of them need to have some load current to work.
I put a small 12v lamp there.
Logged
Offline Offline
Jr. Member
View Profile
Could you please answer the other questions as well?
Logged
Australia
Offline Offline
Full Member
View Profile
ATX supply needs a minimum load on its output to regulate.
If you dont have a load, the output voltages will rise above their nominal values.
Depending on what the switcher chip in the supply is , the supply can shut itself down
if the output voltage goes high.
Depending on the power rating of the supply, you will have to experiment to find out what
minimum load is needed.
Logged
Pages: [1]   Go Up
Print
Jump to:
