Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Soil Moisture sensor  (Read 1569 times)
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
OOPS!  smiley-red smiley-red smiley-red
did not check the code well enough ...
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Dallas, TX
Offline Offline
Sr. Member
View Profile
 smiley Not surprising, it goes on for a bit.
Logged
Offline Offline
Newbie
View Profile
... and the sensorPin suppose to be A0, A1 like robtillaart said ... Hardware serial is digital pin not analog no? So no conflict !
Logged
Dallas, TX
Offline Offline
Sr. Member
View Profile
Correct. It's hard to tell what your current code is.
Logged
Offline Offline
Newbie
View Profile
Only the define of sensorPin has changed ....
Code:
#define voltageFlipPin11 2
#define voltageFlipPin12 3
#define voltageFlipPin21 4
#define voltageFlipPin22 6
#define voltageFlipPin31 7
#define voltageFlipPin32 8
#define voltageFlipPin41 9
#define voltageFlipPin42 11
#define sensorPin1 A4
#define sensorPin2 A2
#define sensorPin3 A1
#define sensorPin4 A0
int flipTimer = 1000;
int currentsensor=1;
int val11;
int val12;
int avg1;
int val21;
int val22;
int avg2;
int val31;
int val32;
int avg3;
int val41;
int val42;
int avg4;
void setup(){
  pinMode(voltageFlipPin11, OUTPUT);
  pinMode(voltageFlipPin12, OUTPUT);
  pinMode(voltageFlipPin21, OUTPUT);
  pinMode(voltageFlipPin22, OUTPUT);
  pinMode(voltageFlipPin31, OUTPUT);
  pinMode(voltageFlipPin32, OUTPUT);
  pinMode(voltageFlipPin41, OUTPUT);
  pinMode(voltageFlipPin42, OUTPUT);
  digitalWrite(voltageFlipPin11, LOW);
  digitalWrite(voltageFlipPin12, LOW);
  digitalWrite(voltageFlipPin21, LOW);
  digitalWrite(voltageFlipPin22, LOW);
  digitalWrite(voltageFlipPin31, LOW);
  digitalWrite(voltageFlipPin32, LOW);
  digitalWrite(voltageFlipPin41, LOW);
  digitalWrite(voltageFlipPin42, LOW);
  pinMode(sensorPin1, INPUT);
  pinMode(sensorPin2, INPUT);
  pinMode(sensorPin3, INPUT);
  pinMode(sensorPin4, INPUT);
void loop(){
  switch (currentsensor){
  case 1:
    digitalWrite(voltageFlipPin11, HIGH);
    delay(flipTimer);
    val11 = analogRead(sensorPin1);
    delay(flipTimer);
    digitalWrite(voltageFlipPin12, HIGH);
    delay(flipTimer);
    val12 = 1023 - analogRead(sensorPin1);
    avg1 = (val11 + val12) / 2;
    ++currentsensor;
  case 2:
    digitalWrite(voltageFlipPin21, HIGH);
    delay(flipTimer);
    val21 = analogRead(sensorPin2);
    delay(flipTimer);
    digitalWrite(voltageFlipPin22, HIGH);
    delay(flipTimer);
    val22 = 1023 - analogRead(sensorPin2);
    avg2 = (val21 + val22) / 2;
    ++currentsensor;
  case 3:
    digitalWrite(voltageFlipPin31, HIGH);
    delay(flipTimer);
    val31 = analogRead(sensorPin3);
    delay(flipTimer);
    digitalWrite(voltageFlipPin32, HIGH);
    delay(flipTimer);
    val32 = 1023 - analogRead(sensorPin3);
    avg3 = (val31 + val32) / 2;
    ++currentsensor;
  case 4:
    digitalWrite(voltageFlipPin41, HIGH);
    delay(flipTimer);
    val41 = analogRead(sensorPin4);
    delay(flipTimer);
    digitalWrite(voltageFlipPin42, HIGH);
    delay(flipTimer);
    val42 = 1023 - analogRead(sensorPin4);
    avg4 = (val41 + val42) / 2;
    ++currentsensor;
  case 5:
    Serial.print("Sensor Value #1: ");
    Serial.println(avg1);
    Serial.print("Sensor Value #2: ");
    Serial.println(avg2);
    Serial.print("Sensor Value #3: ");
    Serial.println(avg3);
    Serial.print("Sensor Value #4: ");
    Serial.println(avg4);
    Serial.println("-----------------------");
     Serial.print("Average Sensor Value: ");
    Serial.println((avg1+avg2+avg3+avg4)/4);
    currentsensor=1;
Logged
Offline Offline
Newbie
View Profile
.... Another question ... Why when i wrote that:
Code:
Serial.print(100-(avg2*100/1010));
If avg2=1000, I receive 130 ... ???
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
there is an int overflow, make all constants long by adding the L modifier to them
Serial.print(100L - (avg2*100L/1010L) );
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Tanks, that work but now to want to know why smiley-razz ....
The biggest number i have in this formula is 100000 (avg2*100) ... That's why i have this problem due to integer limitation of 32767??
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Yes, (even unisgned int would be too small)
looking at the formula you can work around it as follows too:
Serial.print(100 - (avg2*10/101) );  // removed a common factor 10
avg2 *10 is max 10000, divided by 101 is 99 or so all within int range
Q: why divide by 101? what is the range you expect in the print? 1..100 or 0..100?
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
1010 it's the Max of what i can read with the sensor... I want to show in % the soil humidity but Another problem is i dont think the soil resistance increase is linear so maybe i do this for nothing smiley-razz
Logged
Offline Offline
Newbie
View Profile
I think i will have to do test by soil weight to know the humidity level and the reading according to that!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Check my multiMap() on the playground, it is invented for non linear thingies. See - http://playground.arduino.cc/Main/MultiMap -
(time for a cup of tea smiley-wink
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Quote
ok i read it but i not sure to understand what i'm reading smiley-razz
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
multimap() interpolates between points in a lookup table. Better?
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
...... maybe... so i make my test with weight/read tu deternine the % of water in the soil and then i enter the value in multimap() (ex: 5%,10%,15% etc...) and the corespondant reading (ex:1000,950,900 etc...) and .....
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
