Topic: Mega 2560 Serial Port trouble (Read 972 times) previous topic - next topic
runner
I am working a project with an arduino mega 2560. I have Installed the drivers and they work fine but when I tried to test the board with a servo sweep program from the arduino site, nothing happened. I get the error that says serial port COM1 not found. I go to tools to fix this and the serial port option is greyed out and I cannot access it. There is nothing attached to the arduino except the usb cable. Therefore I do not know how to upload any programs to the board. Thanks!
Runner
ematson5897
Try these things:
1. restarting your computer
2. different USB port
3. different USB cable
4. different computer
oric_dan
I may be wrong, but seems to me that it's unlikely the PC would be using such a low
port number as COM1 for the Arduino. You might try reinstalling the drivers. Also,
go to the Control Panel > System > Hardware > Device Manager, and see if the Mega
board shows up in the Ports section when you plug in the board. It should.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
