Topic: 3v regulator needed (Read 982 times) previous topic - next topic
Carlcox89
hi, i've made an arduino stripboard and need to connect a nrf24l01 that needs a maximum of 3.6v.
What's the best/cheapest regulator i can use to go from 5v to 3.3v or approximately ?
thanks
Grumpy_Mike
I have uses an A033 regulator to get 3V3 from 5V.
Carlcox89
Is it this one http://pdf1.alldatasheet.com/datasheet-pdf/view/111555/ROHM/BA033T.html ?
thanks
dc42
LarryD
You can use:
No technical PMs.
The last thing you did is where you should start looking.
Grumpy_Mike
You can use:
You can but the regulation  is not very good and I would at least include some capacitors.
LarryD
Note:
No technical PMs.
dhenry
I am 100% sure that they are not the best, but the 1117s are the cheapest and crappiest regulator that gets the job done.
oric_dan
If you actually look at the datasheet for a 1N400x diode, you'll see it's forward
drop varies from about 0.6V @ 50mA to about 0.8V at 250mA, so the output
of the 3 diode ckt will vary from about 3.2V to 2.6V with those loads. I'd go
with an LM1117, or other v.reg as mentioned, instead.
