Topic: Help seeed bluetooth shield (Read 4082 times) previous topic - next topic
CCJAD
I recently just purchased the Seeed bluetooth shield from Radioshack (http://www.radioshack.com/product/index.jsp?productId=12688459)i am using Arduino UNO R3 .I found this http://www.seeedstudio.com/wiki/Bluetooth_Shield but it didn't really help me i installed the two libraries and up loaded slave but it didnt work it came up with an error . I spent three days trying to figure out how to use it but I'm so lost could someone please help me? it would be much appreciated.
PaulS
Which you are not interested in fixing, apparently, or you would have told us what it was. And posted the code.
CCJAD
Sorry the error is
Slave:37: error: 'NewSoftSerial' does not name a type
Slave.pde: In function 'void loop()':
Slave:52: error: 'blueToothSerial' was not declared in this scope
Slave:58: error: 'blueToothSerial' was not declared in this scope
Slave.pde: In function 'void setupBlueToothConnection()':
Slave:65: error: 'blueToothSerial' was not declared in this scope
this is the code im using im not the best coder so idk whats wrong i have the board setup just like on the wiki page
BluetoothShield Demo Code Slave.pde. This sketch could be used with
Master.pde to establish connection between two Arduino. It can also
be used for one slave bluetooth connected by the device(PC/Smart Phone)
with bluetooth function.
2011 Copyright (c) Seeed Technology Inc.  All right reserved.
Author: Steve Chang
This demo code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
For more details about the product please check http://www.seeedstudio.com/depot/
/* Upload this sketch into Seeeduino and press reset*/
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 6
#define TxD 7
#define DEBUG_ENABLED  1
NewSoftSerial blueToothSerial(RxD,TxD);
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
  char recvChar;
  while(1){
    if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
      recvChar = blueToothSerial.read();
      Serial.print(recvChar);
    if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
      recvChar  = Serial.read();
      blueToothSerial.print(recvChar);
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
PaulS
What version of the IDE are you using? Prior to 1.0, NewSoftSerial was a user downloaded library. With 1.0 and on, NewSoftSerial was adopted as an official library, and renamed SoftwareSerial.
CCJAD
ok so i went in total nerd mode missed a day of school spent the whole day to figure this out . so i used this code that i changed a little bit
//Author: Steve Chang
#define RxD 6
#define TxD 7
const int right = 8;
const int left = 9;
const int headlight = 10;
const int pingPin = 11;
int incomingByte;
SoftwareSerial blueToothSerial(RxD,TxD);
  pinMode(right, OUTPUT);
  pinMode(left, OUTPUT);
  pinMode(headlight, OUTPUT);
  char recvChar;
  while(1){
    if (recvChar == 'F') {
      digitalWrite(right, LOW);
      digitalWrite(left, LOW);
    // if it's an L (ASCII 76) turn off the LED:
    if (recvChar == 'L') {
      digitalWrite(left,HIGH);
    if(recvChar == 'R') {
      digitalWrite(right,HIGH);
    if(recvChar == 'S') {
      digitalWrite(right, HIGH);
      digitalWrite(left, HIGH);
    if(recvChar == 'J') {
      digitalWrite(headlight, HIGH);
    if(recvChar == 'K') {
      digitalWrite(headlight, LOW);
this is the original code
Author: Steve Chang
#define RxD 6
#define TxD 7
  char recvChar;
  while(1){
See i changed NewSoftSerial blueToothSerial(RxD,TxD); to SoftwareSerial blueToothSerial(RxD,TxD);
and i put all my other code in the while statement and changed the incomingByte/Serial.read to recvChar in the if statement
and now every thing is working nice that code is the code i used on my first wireless non autonomous robot  XD
PaulS
Great. Now, get rid of the infinite loop (while(1) {}) inside the infinite loop (loop()).
CCJAD
:( ok now i have another problem i was doing good then i took a break for like a week came back
uploaded my edited sketch and now my phone detects the the seed slave it then says "connecting..."
then "Bluetooth serial port connection fail."
