Topic: Project suggestion! (Read 1 time) previous topic - next topic
deathbyte
Hey,
I need some project idea for my academics. I'm Electronics & communication engineer. So please suggest me nice micro controller (with or without Arduino). Its for my academics so please suggest a nice one.
Please do help!
LarryD
Since this is an Arduino forum why not try Arduino, UNO Rev3 is a great choice.
How far have you gone in writing software and electronics design?
No technical PMs.
The last thing you did is where you should start looking.
Arrch
Why don't you start with what interests you...
deathbyte
I cant use ready made boards available. I have to etch it. About programming well, i cant write a code after a few trial and errors
HazardsMind
Ok then download the arduino schematic and etch your own board. The Arduino teams allows people to modify their design to come up with new board ideas.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
CrossRoads
Plenty of standalone designs have been posted here. Find one of those, and use a standalone ICSP programmer to put bootloader code into it.
example:
https://www.sparkfun.com/products/9825
Then use standalone USB/Serial adapter for debugging via Serial Monitor/USB port.
example:
https://www.sparkfun.com/products/9716
Put header pins on your board so you can plug these in directly.
You can download sketches with just the first, but you don't get the USB interface then.
You can't download the bootloader with the second one.
robtillaart
What to think of a board that can harbour 1 to 4 328's that are connected through the I2C bus (1 master rest  slaves) but have the rest of the pins free.
sort of distributed node with max 40 IO pins   max 20 ADC lines   max 10 PWM or so.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
CrossRoads
So something like 2 of these?
Schematic here
http://www.crossroadsfencing.com/BobuinoRev17/
Outer pins are almost all GNDs, leave off if don't need.
20 IO/chip - 6 can be ADC, 6 others can be PWM.
I've designed a Dual '1284P board as well. Haven't ordered any.
32 IO/chip.
robtillaart
Rob Tillaart
