Topic: OSX 10.8 - Arduino Due - Serial ports not showing (Read 9130 times) previous topic - next topic
ghulands
I plugged it into the windows box i have and when connected to the programming port it doesn't do anything and when I plug in the native one, windows complains about the USB device having an issue.
I've just ordered the black magic probe to see if i can recover the device, if not I will send it back for replacement.
I'll keep this thread updated for the resolution.
Thanks,
Greg
James C4S
Or you might consider starting a new thread with the resolution since it really has nothing to do with the original poster's topic.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Truegrip
Hello,
i have the same Problems: ATmega 168 with a MacOX 10.6.8
PWR light is green 13 red is blinking...tried 4 different USB Cables , on Systemprofiler no Arduino device shows up .
please help ;)
James C4S
No, you don't have the same problem.  The due doesn't haven't an atmega168.
You likely have a board at uses a FTDI chip and so you need to install FTDI drivers.
Red... So it isn't an Arduino.
Truegrip
it is a CB from Arduino.
green PWR-light is on / the light "13" is blinking
all is from a Arduino starter box,
as usual all this s+++t starts with frustration instead of fun XD
ghulands
This thread was about the Arduino Due which runs an ARM chip. The one you have uses an ATMega chip. They use different chips for the serial ports.
I'd suggest starting a new thread for you question.
James C4S
What is a CB?
You said red, but I think the LED is actually Amber.  Cheaply made clones use actual Red LEDs (because they are cheaper.)
Then the chip can't be a ATmega168.
As Greg points out and as I did, your issue has nothing to do with this thread.  You have a similar issue, but not the same problem.
Loonhaunt
I see no evidence that this was ever answered.  I just purchased a Due for the extended IO.. Seems that I may have been Hosed, as I am having this problem also.  And documentation is pretty horrible.
