Loading...
Pages: [1]   Go Down
Author Topic: NFC Success! - Interfacing with Mifare  (Read 847 times)
Australia
Offline Offline
Newbie
View Profile
I am very much a novice with arduino and want to share my success with anyone thinking of a similar project with NFC.
I am building a card reader for my primary school classroom that records when students enter the room using their "smart cards", then a random good morning message is played using a wav shield also attached to the UNO.
After a LOT smiley-mad of searching on the web, I actually found the code that works... almost!
Code:
//This example reads all MIFARE memory block from 0x00 to 0x63.
//It is tested with a new MIFARE 1K cards. Uses default keys for authenication.
//Contributed by Seeed Technology Inc (www.seeedstudio.com)
#include <PN532.h>
#include <SPI.h>
/*Chip select pin can be connected to D10 or D9 which is hareware optional*/
/*if you the version of NFC Shield from SeeedStudio is v2.0.*/
#define PN532_CS 10
PN532 nfc(PN532_CS);
#define  NFC_DEMO_DEBUG 1
void setup(void) {
#ifdef NFC_DEMO_DEBUG
  Serial.println("Hello!");
#endif
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
#endif
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata>>8) & 0xFF, DEC);
  Serial.print("Supports ");
  Serial.println(versiondata & 0xFF, HEX);
#endif
  // configure board to read RFID tags and cards
  nfc.SAMConfig();
void loop(void) {
  uint32_t id;
  // look for MiFare type cards
  id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
  if (id != 0)
    Serial.print("Read card #");
    Serial.println(id);
#endif
    uint8_t keys[]= { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF };// default key of a fresh card
    for(uint8_t blockn=0;blockn<64;blockn++)
      if(nfc.authenticateBlock(1, id ,blockn,KEY_A,keys)) //authenticate block blockn
        //if authentication successful
        uint8_t block[16];
        //read memory block blockn
        if(nfc.readMemoryBlock(1,blockn,block))
          //if read operation is successful
          for(uint8_t i=0;i<16;i++)
            //print memory block
            Serial.print(block[i],HEX);
            if(block[i] <= 0xF) //Data arrangement / beautify
              Serial.print("  ");
              Serial.print(" ");
          Serial.print("| Block ");
          if(blockn <= 9) //Data arrangement / beautify
            Serial.print(" ");
          Serial.print(blockn,DEC);
          Serial.print(" | ");
          if(blockn == 0)
            Serial.println("Manufacturer Block");
            if(((blockn + 1) % 4) == 0)
              Serial.println("Sector Trailer");
              Serial.println("Data Block");
#endif
  delay(2000);
On the console a dec. id is printed out but it does not work with the "if" statements I am trying!
This is the console monitor printout:
Hello!
Found chip PN532
Firmware ver. 1.6
Supports 7
Found 1 tags
Sens Response: 0x4
Sel Response: 0x8
 0x4A 0x3 0xD5 0xD6Read card #1241765334
A little tweaking of code is required - of the card's decimal ID (1241765334) to enable an if/else statement to work. Here is the MIfare code THAT I HAVE WRITTEN onto line 56:
Code:
//This changes the crazy id into an integer that actually works
int x;
x = id;
Serial.print("New card id # is");
Serial.println(x);
The serial monitor now says
Hello!
Found chip PN532
Firmware ver. 1.6
Supports 7
Found 1 tags
Sens Response: 0x4
Sel Response: 0x8
New card id # is-10794
Now that you have that new id (-10794), it works with if statements, like say good morning to a particular student whereas I could not get anything to happen with the old id (1241765334).
If anyone can tell me what is happening here I would appreciate your comments.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Truncating a 32 bit value to fit in 16 bits doesn't seem like a good idea.
Quote
The if statements that you didn't bother to show?
Quote
What is happening is that you didn't post all of your code, apparently.
Logged
Australia
Offline Offline
Newbie
View Profile
I know I left out a lot of information this morning. I was pretty wrapped to actually make something happen the way I wanted it to.
Firstly I forgot to say which  shield I am using:
http://littlebirdelectronics.com/search?type=product&q=nfc
I purchased 25 book tags as well for the students in my class.
Secondly I am using PN532 library http://www.seeedstudio.com/wiki/File:PN532_SPI_V2.zip
As I am a novice at arduino, my latest sketch is still reading and printing my card ids ( I know all of my 25 ids now so I will take that code out tomorrow. Here it is in its entirety...
Code:
#include <PN532.h>
#include <SPI.h>
#define PN532_CS 10
void setup(void) {
#endif
  nfc.begin();
#endif
    while (1); // halt
  Serial.print('.');
#endif
  nfc.SAMConfig();
void loop(void) {
  uint32_t id;
  if (id != 0)
    Serial.println(id);
int x;
x = id;
Serial.println(x);
if (id = -10794)
  Serial.print("Good Morning John");
#endif
        uint8_t block[16];
              Serial.print("  ");
              Serial.print(" ");
            Serial.print(" ");
          if(blockn == 0)
#endif
  delay(2000);
I added is these lines to the code I found:
    Serial.println(id);
int x;
x = id;
Serial.println(x);
if (id = -10794)
It works great and prints Good Morning John on the serial monitor.
Next I will try lighting a led if the card id is correct - I think I need more power as the leds I have connected glow very dim - maybe it is the usb power.
The reason I am writing all of this down is I think this information will assist others who have a similar project in mind. I found it difficult to locate the code I needed and am happy it has worked out. This is a great learning experience and I would like to see schools facilitating learning through mistakes - just as I have done.
I am sure there are many other ways to activate an output from mifare card but at the moment this is working fine.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
    Serial.println(id);
int x;
x = id;
Serial.println(x);
if (id = -10794)
In place of?
Let me guess. You had something like:
Code:
if(id == 1241765334)
   // Do something
and that didn't work, because none of the if blocks ever evaluated to true.
Try this:
if(id == 1241765334UL)
   // Do something
The first snippet fails because, in the absence of directives to the contrary, literal constants are treated as ints. 1241765334 is not an int. In the second snippet, there is a directive to the contrary that tells the compiler to treat the literal constant as an unsigned long, rather than an int. Since 1241765334 is a valid unsigned long, it will match id, and the block will be executed.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Or the pin that the LED is connected to needs to be defined (using pinMode()) as an OUTPUT pin.
Logged
Australia
Offline Offline
Newbie
View Profile
Thanks Paul S. Your advice is very much appreciated. I am going to rewrite:
   // Do something
and
(using pinMode())
for my led.
Cheers again!!!!
Logged
Pages: [1]   Go Up
Print
Jump to:
