Loading...
Pages: [1]   Go Down
Author Topic: Q about power sources  (Read 218 times)
Kansas
Offline Offline
Newbie
I AM ON FIRE!!!!!!!!!!!!!!!!!!!.................get a fire extenguisher, please?
View Profile
hi, i am very new to arduino and have little to no experience with this type of hardware
 and was wonderin if i was to connect some motors to my arduino can I construct or buy somethin that would allow me to run power to the motors without running it through the arduino?
  (the electric moters i was planning to use come from a toy bulldozer and use 4 or maybe 6 D -ize batteries and i dont think i should pull that amount of current or power through the arduino circut)
any help would be appreciated
Logged
Offline Offline
Sr. Member
The last thing you did is where you should start looking.
View Profile
Relays and Transistors will isolate your Arduino from your motors.
Logged
Kansas
Offline Offline
Newbie
View Profile
thanks, now to google those things
Logged
Offline Offline
Sr. Member
View Profile
http://arduino-info.wikispaces.com/RelayIsolation
http://arduino-info.wikispaces.com/DC-Motors
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
You might also find this useful: it explains the transistor in words that made sense even to moi.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Most DC motor controller boards and shields (like the popular ones based on the L293 and L298) for the Arduino allow you to power the motors via an external power source. Some require the Arduino board to supply the logic supply for the h-bridge; others have an on-board regulator, and can take the power from the motor supply. Some have jumpers to select what you want; some can even power the Arduino (ie, the supply for the motor and driver board also powers the Arduino).
Above all else, you need to know the voltage of your motors, and the worst-case (stall) current needs of them - before you can select -any- controller. If you don't have a multimeter to measure this, that meter should be your -first- purchase.
Logged
Pages: [1]   Go Up
Print
Jump to:
