Topic: OneWire in Due (Read 43504 times) previous topic - next topic
pjrc
I'm getting ready to publish OneWire 2.2.  Here's a preview version:
http://www.pjrc.com/teensy/beta/OneWire_preview22_17jan13.zip
If anyone has any feedback regarding how OneWire 2.2 should look, please speak up ASAP!
alvesjc
Unfortunatly, can't test it... argh...
www.aqualedsource.com
kcore
Paul,
I'm having problems reading from multiple DS18B20's with your 2.2 preview library.
Fresh copy of arduino-1.5.1r2-windows, and downloaded just your 2.2 preview library, and I run the DS18x20_Temperature sketch with three of the DS18B20's attached to Due pin 54 (Analog line 0) and I get the following:
No more addresses.
No more addresses.
No more addresses.
If I pull two of the sensors out it starts returning results although sometimes it returns results like the following:
ROM = 28 F6 C3 49 3 0 0 25
  Chip = DS18B20
  Data = 0 FF FF FF FF FF FF FF FF FF  CRC=C9
  Temperature = 4095.94 Celsius, 7404.69 Fahrenheit
or
  Chip = DS18B20
  Data = 1 50 5 4B 46 7F FF C 10 1C  CRC=1C
  Temperature = 85.00 Celsius, 185.00 Fahrenheit
PaulMcMillan
I'm using the ADK2012 device (with the google-provided IDE), which is very similar to an Arduino Due. When I include the pre-release 2.2 version linked above into a project and compile, I get errors like this:
OneWire.cpp: In constructor 'OneWire::OneWire(uint8_t)':
OneWire.cpp:123: error: base operand of '->' has non-pointer type 'const PinDescription'
OneWire.cpp:124: error: base operand of '->' has non-pointer type 'const PinDescription'
Removing the 2 lines it's complaining about allows it to compile, but unsurprisingly, it doesn't actually work.
I'm new enough to all this that I don't have a good handle on how to get started debugging this. Any ideas?
(I asked this on stackoverflow too: http://stackoverflow.com/q/14669607/114917)
pjrc
#34
Feb 06, 2013, 01:37 am Last Edit: Feb 06, 2013, 01:49 am by Paul Stoffregen Reason: 1
Did you try compiling on Arduino 1.5.1?
Maybe you can copy whatever's ADK2012 is missing from Arduino 1.5.1?
Of course, without fixing delayMicroseconds(), it's unlikely to work reliably.
brendon_lecomte
Is there any way to fix to the delayMicroseconds() issue? or is this something we have to hope the folks at arduino will fix for us? I am using the Ds18b20's for a brewery system and have moved to the due recently and don't want to backtrack to change the sensors
leonid_leonid
#36
Feb 11, 2013, 01:50 pm Last Edit: Feb 11, 2013, 02:13 pm by leonid_leonid Reason: 1
Hi all,
I tried the the OneWire 2.2 with IDE 1.5.1r2. Two of four DS1820 sensors give me no readings ("No more addresses" in the DS18x20 Example sketch), the other two produce no valid temperature readings:
ROM = 10 D1 A2 54 2 8 0 57
  Chip = DS18S20
  Data = 1 FF FF FF FF FF FF FF FF FF  CRC=C9
  Temperature = -0.50 Celsius, 31.10 Fahrenheit
It is probably the delayMicroseconds problem Paul mentioned in his post.
With the new IDE 1.5.2 (http://arduino.cc/forum/index.php?topic=147531.0) all four sensors are unable to be read ("No more addresses").
It's kind of weird...
Have someone else tried 1.5.2 with OneWire yet?
Leo
Update: the OneWire Library with changes by alvesjc and mantoui works with both 1.5.1r2 and 1.5.2. I'm able to read all 4 sensors.
leonid_leonid
Hi Paul,
I just finished diff-and-try session with the library version OneWire_preview22_17jan13.zip and the version from this thread (with changes by alvesjc and mantoui).
The critical point seems to be the write_bit() function and the interrupt handling combined with delayMicroseconds() calls in this function (both have been mentioned in this thread already).
As soon as I excluded delayMicroseconds calls from noInterrupts()/interrupts() sections in the write_bit() function, the library worked.
Here is the changed version of write_bit():
void OneWire::write_bit(uint8_t v)
IO_REG_TYPE mask=bitmask;
volatile IO_REG_TYPE *reg IO_REG_ASM = baseReg;
if (v & 1) {
noInterrupts();
DIRECT_WRITE_LOW(reg, mask);
DIRECT_MODE_OUTPUT(reg, mask); // drive output low
interrupts();
delayMicroseconds(10);
noInterrupts();
DIRECT_WRITE_HIGH(reg, mask); // drive output high
interrupts();
delayMicroseconds(55);
noInterrupts();
interrupts();
delayMicroseconds(65);
noInterrupts();
interrupts();
delayMicroseconds(5);
It's the only change I made on the library.
I'm running a test with all the sensors installed in my house heating control, I have 9 DS1820 for temperature sensing and some DS2408 and DS2413 for relay switching.
All of them are working (so far) as they usually do with my old Arduino Mega. I'll post test results tomorrow.
Leo
pjrc
Interrupts are disabled for a very good reason.  There's absolutely no way OneWire will return to the buggy pre-2.0 days where interrupts could lengthen the timing and cause random communication errors.
leonid_leonid
Ok, I understand that (I do know what are interrupts for and why they are disabled in time critical sections). I do not understand why delayMicroseconds acts differently depending on interrupts being disabled or enabled. Declaration of delayMicrosections for SAM is quite simple (from wiring.c):
void delayMicroseconds( uint32_t us )
    uint32_t start = micros();
    while ((micros() - start) < us)
It did not change since 1.5.1r2.
Do you have an idea, what the solution could be?
Leo
PS if I can contribute in any way, let me know.
Markus_L811
Leo
So the problem must be somewhere behind the micros the function delayMicroseconds is realy open so the problem musst be somewhere there
uint32_t micros( void )
uint32_t ticks ;
uint32_t count ;
SysTick->CTRL;
do {
  ticks = SysTick->VAL;
  count = GetTickCount();
} while (SysTick->CTRL & SysTick_CTRL_COUNTFLAG_Msk);
return count * 1000 + (SysTick->LOAD + 1 - ticks) / (SystemCoreClock/1000000) ;
its in the wiring.c
leonid_leonid
Right, micros() must have a problem with noInterrupts().
I tried to change delayMicroseconds() to make it independent from micros(). Here is the code:
#define CYCLES_PER_USEC 84 // Arduino Due has 84 MHz clock
#define CYCLES_PER_LOOP 6  // one iteration of the loop takes 6 cycles
#define OVERHEAD_CONST 18  // could someone with an osci please verify this constant?
  if(us==1) return;
  int j;
  //one iteration of this loop takes 6 cycles on Arduino Due compiled with IDE 1.5.2
  for(j=0;j<us*(CYCLES_PER_USEC/CYCLES_PER_LOOP)-OVERHEAD_CONST;j++)
    asm volatile("mov r0, r0"); // just NOP
This change worked with the original version of OneWire (OneWire_preview22_17jan13.zip)
This patch is not pretty but it proves that the problem is in the micros().
Tomorrow I'll try to understand, why micros() has a problem with noIterrupts().
cmaglie
Thank you all, guys, for debugging this one.
I've pushed a patch that makes delayMicrosecond() independent from micros().
Paul, I've borrowed the implementation from the Teensy core, if you don't mind!
I've only slightly changed it:
- the "bne" instruction to "bge" to allow delays of 0uS
- changed the calculation of "n" (multiply seems to use 1 cycle as the shift and
makes the formula generic)
https://github.com/arduino/Arduino/commit/7f7637c782fc0c028f0539d27b99f930ee30baa5
@leonid_leonid
sorry, I didn't looked at the forum thread with your implementation!
C.
alvesjc
Hi all.
I'm back in Due.
I've compiled IDE from the latest info in Git, so I'll give a try on the latest lib from Paul later today.
Kuya Marc
Hello World!
Sometime today, I'll be receiving my Arduino Due, and one of my active Arduino projects is using OneWire. After reading through all of the posts, I'm confused on what to do with my current OneWire library. Should I patch it, replace it, or make a new OneWire library parallel to the current one I'm using?
My Project: Arduino Mega 2560: Digital Temperature using DS18B20 and 7-Segments LEDs
I've removed the serial debugging code and simplified my sketch that works on my Arduino Mega 2560 clone.
From this Forum, I've downloaded OneWire.zip and OneWire_preview22_17jan13.zip.
I run Xubuntu Linux as my only computer operating system!
Windows does not run here; Only
