Topic: A Tip: Buttons, Potentiometers and Tilt Sensors . . . (Read 3952 times) previous topic - next topic
imruffsdad
. . . Oh My.  :P
I'm 50 and have been in to some simple electronics for a few years now and I'm having a blast with this Arduino Starter Kit. I want to start a fund to buy one for every 6th grader at my kids elementary school and start an after school club!
That said, here's a tip that has helped me get more enjoyment out of this kit. For all the objects in the Subject line I've soldered mail header pins to the pins of these components. They all either kept popping out of the breadboard or wouldn't go in at all and soldering header pins on to them locks them in solid whenever I used them and they still pop right out. To do this I used the header pins that came with the kit and one of those helping hand vises. In the case of the potentiometer I broke off three male header pins from the strip and pulled out the middle pin keeping the other two held in place by the plastic. So now they are spaced correctly I put one of the pins from the pot in the vise (roach clip is what we called them back in the day) and then in a hand twisting move put one of the two pins in the vise with it. I then soldered the two together and repeated the operation on the other pins. This left me with one side of the pot that had the two pins held together by the plastic holder so their width would always be right and the third pin was soldered to the header pin I pulled out of the middle of the three.
Hope that makes sense. I've attached a picture of the finished product if that helps at all.
All the best,
Dennis
JimboZA
That's nicer than the way I did it... I found the wires on the pot didn't fit snugly in the breadboard holes and did much what you did but just with wire that fitted into the breadboard holes- just used the tails of some resistors iirc.
Yours is a better way, with the pins the right distance apart; mine just with wires still needs a bit of manipulation to line up each time and is also a bit flimsy.
Good idea there. What you've got is a halfway stage between virgin components and the commercially available breakout boards which is just the component (ok, sometimes more than just the component) on a small board with a header.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
