Topic: Which Wire Library Functions Require Slave c2i Device Stacked on Arduino Uno? (Read 436 times) previous topic - next topic
encryptor
Which Wire library functions requires the slave c2i device stacked on Arduino Uno?  Does requestFrom(addy, quantity) or available() require the slave c2i device?  thanks! :smiley-roll-sweat:
peace*&^
johnwasser
Do you mean I2C?  You use the Wire library to communicate with I2C and TWI devices.  If you don't have an I2C or TWI device connected to the I2C pins then the Wire library won't be of any use.
None of the functions of the Wire library "require" that you have a device to communicate with.  If you address a device that is not present the communication will fail.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
