Topic: Problem with error message (Read 2231 times) previous topic - next topic
sakfromdk
Me and my friend don't know how to fix this error, or why it's accouring.
Our code looks like this:
const int buttonPin = 2;
const int hl = 3;
int buttonState = 0;
pinMode(hl, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(hl, LOW);
else {
// turn LED off:
digitalWrite(hl, HIGH);
digitalWrite(hl, low)
delay(1000)
When we try to verify it, we get the error:
Button:57: error: expected unqualified-id before '{' token
Please tell us how to fix the problem!!
guix
#1
Dec 13, 2012, 03:49 pm Last Edit: Dec 13, 2012, 03:52 pm by guix Reason: 1
Hello and welcome :)
You have few problems on the last lines:
- First you forgot some ';'
- Then if you check the count of '{' and '}' (and if you indented your code correctly) then you will see the last lines are outside of void loop().
Here is your code, exactly the same but correctly indented:
Code: [Select]
const int hl = 3;
   // turn LED on:
   // turn LED off:
 delay(1000)
See the problem(s) ??
sakfromdk
Hi, thanks for the help, we tried to look at it again, but the error is still not fixed, maybe I don't really get what the error is. It comes with the same error when we try to put the '{' other places.
Please help.
sakfromdk
Me and my friend don't know how to fix this error, or why it's accouring (we have very little experience with programming).
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
Grumpy_Mike
You must have an equal number of braces both { and }.
The braces must enclose blocks of code.
The braces in that code are all over the place.
Grumpy_Mike
I imagine that this is what you want, but I am not sure.
Code: [Select]
const int hl = 3;
void loop(){
// turn LED on:
else {
// turn LED off:
robtillaart
First, if you post please use the # button to tag code correctly
Give this a try, I removed a { and added an extra delay(200) , .. (code not tested)
Code: [Select]
const int hl = 3;
 delay(200);  // extra
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
UKHeliBob
Problem 1 - all the statements should end with a semi-colon like this
Code: [Select]
Are there any lines in your sketch that don't ?
Problem 2 - when, if ever, is this code going to be executed ?
Code: [Select]
  delay(1000)
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
sakfromdk
Code: [Select]
const int hl = 3;
Hi, it worked, thanks, but why did you make an extra delay, and why did it work???
nickgammon
Please don't cross post. Threads merged.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
robtillaart
Quote
That is your homework:)
Follow the code by hand, read it carefully line by line.
Be the Arduino !
and do what the code says and you will understand.
Rob Tillaart
sakfromdk
Quote
Be the Arduino !
Well, ok, thank you! :)
