Topic: What is the code for making a text flash on LCD screen? (Read 12229 times) previous topic - next topic
apples
Playing with my LCD, what is the code for flashing some written text on the LCD screen?
UKHeliBob
Something like this maybe ?
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
  lcd.begin(16, 2);
  lcd.print("Some text");
  lcd.clear();
apples
Ahh yeah, righto.  I just thought there might be a command line for it already.
Next ?
The text I have displayed now, (just mucking around playing connect 4 with the kids is)
   GAME SCORE
Peter      Nicholas
   0             1
     Game On
Want to make the GAME SCORE flash for example.
That line of code you gave me would make the text flash as long as I repeat it.
But I only want the first line, or 2nd line, or line 1 and line 4 to flash only.
How would you do it then?
Can you have mini loop's going  ie void loop for line 1 of text?  Then normal then void loop for line 4 text?
Peter
UKHeliBob
Have a look at this for some ideas
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("line 1");
  lcd.setCursor(0,1);
  lcd.print("line 2");
  for (int count=0; count <= 5; count++)
    lcd.setCursor(0,0);
    lcd.print("      ");
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("      ");
    delay(200);
    lcd.setCursor(0,1);
    delay(200);
There are better ways to do it but you will get the general idea.
mark7w
Try this.
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7,8,9,10,11,12);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("GAME SCORE");
  // Turn off the cursor:
  lcd.noDisplay();
  delay(250);// change for faster flash
   // Turn on the cursor:
  lcd.display();
metheoneandonly
#5
Jul 27, 2015, 02:07 pm Last Edit: Jul 27, 2015, 02:14 pm by metheoneandonly
Is there really no function to display a portion of flashing text on LCD?
econjack
You can always write your own function. For example:
void FlashMessage(char *msg, int col, int row, int repeat)
  char temp[] = "                ";   // Enough spaces to fill one display line
  lcd.setCursor(col, row);
  lcd.print(msg);
  for (int i = 0; i < repeat; i++) {
    lcd.print(temp);
    delay(PAUSE);
    lcd.print(msg);
    delay(PAUSE);
For example, you could use this:
#define PAUSE  500            // Set at top of source code file
// some code...
  FlashMessage("Game Score", 5, 0, 5);  // Set the message to column 5, row 0, and flash 5 times.
It would be more useful to also pass in the delay period rather than using the #define.
metheoneandonly
