// This is an update to an earlier thread I created that had become muddled with my running commentary trying to get Arduino language support in Notepad++
After several attempts to configure a Arduino bias user defined language for Notepad++ (NPP) I managed to get something close to what I wanted (all the core and standard library keywords) but some keywords would not highlight as expected and I put this down to limitations of the otherwise excellent NPP user language lexicon. I was going to give up at that but then had the idea of adding Arduino keywords to NPP's built in C++ lexicon. This does seem to work better but at the expense of confusing the C++ language for pure C++ programming. My final solution was to download a portable version of NPP and perform my Arduino C++ additions on this copy so I have a normal C++ version to fall back on if needed.
If your interested then download and extract a portable version of NPP via here
http://portableapps.com/apps/development/notepadpp_portableLoad it up, configure it to you liking and install any plugins you use.
Open Style Configurator (Settings->Style Configurator...)
Under 'Language' select 'C++' and then select 'INSTRUCTION WORD' under 'Style'. This should show two text boxes on the right called 'Default keywords' & 'User-defined keywords'.
Copy & paste the line below that begins 'abs accept' into the 'User-defined keywords' text box.
Under 'Style' select 'TYPE WORD' and copy & paste the below line beginning 'ANALOG_MESSAGE' into the 'User-defined keywords' text box.
Under 'User ext.' type 'ino' (without the ' markers) into the box provided
Finally, click 'Save & Close' button and you should now have a portable Arduino bias C++ editor in NPP
INSTRUCTIONS
abs accept acos analogRead analogReference analogWrite asin atan atan2 attach attached attachInterrupt autoscroll available begin beginPacket beginTransmission bit bitClear bitRead bitSet bitWrite blink blinkVersion BSSID callbackFunction ceil char class clear click Client close connect connected const constrain cos createChar cursor degrees delay delayMicroseconds detach detachInterrupt digitalRead digitalWrite direction disconnect display double EEPROM encryptionType end endPacket endTransmission Ethernet EthernetClient EthernetServer exists exp File find findUntil Firmata float floor flush gatewayIP getResult getSocket highByte home int int16_t int32_t int64_t interrupts IPAddress isListening isPressed Keyboard leftToRight LiquidCrystal listen localIP log long loop lowByte macAddress map max micros millis min mkdir Mouse move NewSoftSerial noAutoscroll noBlink noCursor noDisplay noInterrupts noTone null onReceive onRequest open overflow parseFloat parseInt parsePacket peek pinMode position press print printFirmwareVersion println printVersion private processInput prog_char prog_int16_t prog_int32_t prog_int64_t prog_int8_t prog_uchar prog_uint16_t prog_uint32_t prog_uint64_t prog_uint8_t prog_void PROGMEM protected public pulseIn radians random randomSeed read readBytes readBytesUntil readMicroseconds receive register release releaseAll remoteIP remotePort remove requestFrom rightToLeft rmdir round RSSI scrollDisplayLeft scrollDisplayRight SD seek send sendAnalog sendDigital sendDigitalPort sendDigitalPortPair sendString sendSysex Serial Serial1 Serial2 Serial3 Server Servo setBitOrder setClockDivider setCursor setDataMode setFirmwareNameAndVersion setFirmwareVersion setSpeed setTimeout setup shiftIn shiftOut short signed sin size speed SPI sq sqrt SSID static status step Stepper stop String stringCallbackFunction subnetMask sysexCallbackFunction systemResetCallbackFunction tan tone transfer uint16_t uint32_t uint64_t uint8_t unsigned version void WiFi WiFiClient WiFiServer Wire word write writeMicroseconds
TYPES
ANALOG_MESSAGE ANALOG_PORT BIN CHANGE DEC DEFAULT DIGITAL_MESSAGE END_SYSEX EXTERNAL FALLING FILE_READ FILE_WRITE HALF_PI HEX HIGH INPUT INPUT_PULLUP INTERNAL INTERNAL1V1 INTERNAL2V56 LOW LSBFIRST MAX_DATA_BYTES MSBFIRST OCT OUTPUT PI PWM REPORT_ANALOG REPORT_DIGITAL REPORT_VERSION RISING SERIAL_5E1 SERIAL_5E2 SERIAL_5N1 SERIAL_5N2 SERIAL_5O1 SERIAL_5O2 SERIAL_6E1 SERIAL_6E2 SERIAL_6N1 SERIAL_6N2 SERIAL_6O1 SERIAL_6O2 SERIAL_7E1 SERIAL_7E2 SERIAL_7N1 SERIAL_7N2 SERIAL_7O1 SERIAL_7O2 SERIAL_8E1 SERIAL_8E2 SERIAL_8N1 SERIAL_8N2 SERIAL_8O1 SERIAL_8O2 SET_PIN_MODE SPI_CLOCK_DIV128 SPI_CLOCK_DIV16 SPI_CLOCK_DIV2 SPI_CLOCK_DIV32 SPI_CLOCK_DIV4 SPI_CLOCK_DIV64 SPI_CLOCK_DIV8 SPI_MODE0 SPI_MODE1 SPI_MODE2 SPI_MODE3 START_SYSEX SYSTEM_RESET TOTAL_ANALOG_PINS TOTAL_DIGITAL_PINS TOTAL_PORTS TWO_PI
04/03/2013 Edit to update install instructions.
