0
Offline
Newbie
Arduino rocks
« on: January 06, 2013, 03:22:18 am » |
An Arduino Uno costs $30. An Uno with Ethernet costs $65. A Raspberry Pi with Ethernet, 512MB RAM, HDMi video and an SD card slot costs $40. An Adafruit Ethernet shield sells for $45, more than the complete Raspberry Pi.
Presumably the adding Ethernet to a Pi cost a few dollars. Why is Ethernet so expensive with Arduino?
Julian
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #1 on: January 06, 2013, 03:47:32 am » |
cause its custom external hardware no one uses to handle the bulk of the interface, the pi has it in the chip to start with
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
0
Offline
Newbie
Arduino rocks
« Reply #2 on: January 06, 2013, 04:13:35 am » |
Looking at the schematics, the Raspberry Pi seems to use a LAN9512 "Hi-Speed USB 2.0 hub and high-performance 10/100 Ethernet controller". On Digikey these are $3.80 for 100+.
The Wiznet ethernet chip used in the Uno Ethernet costs $4.76 for 100+ from Sparkfun.
These two solutions seem comparable to me. I still don't understand why adding Ethernet to an Arduino costs more than the Arduino on its own. I appreciate costs go down with volumes but an Ethernet shield is still at the top end of shield prices.
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #3 on: January 06, 2013, 06:10:59 am » |
In another thread someone proposed to use the Pi as the new ethernet "device" for Arduino.. Makes sort of sense ....
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #4 on: January 06, 2013, 07:24:24 am » |
These two solutions seem comparable to me. I still don't understand why adding Ethernet to an Arduino costs more than the Arduino on its own. I appreciate costs go down with volumes but an Ethernet shield is still at the top end of shield prices. The schematics and circuit board design are available, at no cost. The list of parts used is available, at no cost. If you think you can source all the parts, and assemble your own board cheaper, go right ahead.
Logged
Chile
Offline
Edison Member
Arduino rocks
« Reply #5 on: January 06, 2013, 11:40:15 am » |
Logged
Tacoma, WA
Offline
Full Member
Arduino rocks
« Reply #6 on: January 06, 2013, 11:46:07 am » |
eried: That is an ENC28j60 chipset, not a Wiznet. It will gobble up the ram on an Uno like nobodies business, and the standard ethernet library doesn't support it AT ALL. BTW: If you think the ethernet is expensive, look at the WiFi.. EeeGads.. I suppose if you HAVE to prototype a WiFi setup... Remember the Arduino is just an educational/prototyping platform. Prototyping is generally always more expensive than mass production, even if this is prototyping on a mass scale.
Logged
Brian from Tacoma, WA Arduino evangelist - since Dec, 2010.
Chile
Offline
Edison Member
Arduino rocks
« Reply #7 on: January 06, 2013, 02:03:59 pm » |
http://www.ebay.com/itm/Ethernet-Shield-W5100-For-Arduino-2009-UNO-Mega-1280-2560-/270955738702?pt=LH_DefaultDomain_0&hash=item3f1638764eLittle extra <10 usd
Logged
