Topic: Data logging with Mega 2560 using Max3232 (Read 5423 times) previous topic - next topic
new_ar
Hi all,
I am trying to use the Serial1, Serial2 and Serial 3 (pin 14-19) of my arduino 2560 to read digital signal of my lab's instruments. I used a RS232 to TTL board (MAX3232) to convert the digital signals from the instruments, however there is no response.
I did some simple test.
i  sent out some letters through the MAX3232 and the used a rs232 to usb converter to convert the signal and my computer can receive the letters and displayed using the arduino software. however, when i send back some letters, the ardunio could not receive.
Here is the code:
void setup(){
  Serial1.begin(9600);
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
void loop(){
   // to display something in arduino software
    Serial1.write("Waiting Signal....");
    Serial1.println("");
    // to see if mega2560 recieve anything from the computer
    if (Serial1.available()){
      int aaa = Serial1.read();
      Serial1.println(aaa);
      digitalWrite(13, HIGH);
actually i received some random number for the variable "aaa" and the LED always turned on.
Do you know how can I change the code so that I can receive digitial signal from rs232 using max3232 and the mega 2560 board.
Hope you can help!
johnwasser
Code: [Select]
The fact that the LED comes on and you get numeric character codes displayed means that your Arduino DID receive data from the PC.  Perhaps you should look for characters more often than once per second:
Code: [Select]
  Serial1.println("Waiting Signal....");
    // If mega2560 recieve anything from the computer, echo it back
    if (Serial1.available()) {
      Serial1.write(Serial1.read());
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
fela
I have had strange datas also when RS232 GND and Arduino GND were not connected...
tforideshd
I found that Serial1.available() is unreliable.
Try Serial1.readBytesUntil ('/n',....,....);
TFO
