Topic: HacroCam - recalculate to greyscale before sending (processing example) (Read 9014 times) previous topic - next topic
robvoi
@Hacrocam users
Attached you find an updated arduino library, the arduhub sketch and an updated processing example for the Hacrocam.
The update allows to convert the image to 8bit grayscale before submitting it via serial link. This halves the time required for the transfer. Great for low baud rate serial links.
In addition you can take more than one picture without restarting the sketch. Press w to take a picture.
The processing example has an added user definable variable g_grayscaleImage to enable/disable grayscale convertion.
Many thanks @robtillaart who solved the hard part. I just put together the puzzle pieces and extended the library and sketches.
Trying to extend it with a 4bit grayscale option now.
Robert
robtillaart
HI,
I did have the same idea yesterday to get a 4bit gray-scale image.
Another idea is to send an image progressively. Suppose you have an image of 8x8 pixels. Then you send the pixels in this order:
// layer 0 lowest resolution (stepsize n/2)
[0,0]
[4,0]
[0,4]
[4,4]
// layer 1  (stepsize n/4 but not those already send)
[2,0], [6,0]
[0,2], [2,2], [4,2], [6,2]
[2,4], [6,4],
[0,6], [2,6], [4,6], [6,6]
// layer 2 (stepsize n/8 but not those already send => which are all remaining pixels for an 8x8 bitmap.
[1,0], [3,0], 5,0], [7,0]
etc
There advantage of progressive images is that you get an idea of the overall picture and it refines gradually.
It also allows to stop transmitting when the resolution is high enough.
Besides the proposed schema, there are many more schemas. The best known is the alternating lines.
First send all the even lines and than all odd lines.
Another speed up of transmission could be run length encoding. This is especially useful if you go to the 4 bit modes.
A byte could become a {run length; colour } tuple, with a run length of 1..15 and a 4 bit colour.
If you have 6 bytes of a certain colour (e.g. colour 9) you send { 6, 9 } or as byte B0110 1001
Rob Tillaart
robvoi
send an image progressively is a good idea. Unfortunately in my case it will not work for two reasons:
1)
The image gets streamed from the camera to the Arduino via TWI/I2C though a 32byte buffer (so 16 pixels).
Only the buffer can be reworked. That's because auf the limited RAM available. The image in total would not fit into the RAM.
I could download the image pixel by pixel from the cam. But this would slow things down again an negate the compression work done.
2)
At the moment in Processing the picture doesn't get rendered during the download. I tried to change that (to see the pixels arriving) but didn't succeed. As I am one of the many victims of the "new topic button now showing in the Processing forum" bug, I can't even post to get help there. ?
The run length encoding is interesting too. But I would lose half of the space for pixels. Maybe it would be possible to mix 4bit grayscale and run length encoding with some signaling byte. But as I can only process 16 pixels at a time, I am not sure if this in reality would improve speed. Taking into account the lost information space and the calculation time.
I looked at other compression methods. But they are all too heavy for an Arduino.
I also looked at other color schemes. 3-3-2 RGB looked nice too. But as far as I read the shading depth is more important for the human brain than the color. (especially for me, as I am partially color blind  XD )
If you have more ideas - please through them in. Maybe we get it to stream a video over the 115k baud.  ]:D
Thanks
Robert
robvoi
I tried the 4bit grayscale. The saved trasmission time gets eaten up by the calculation time. It may still be worth the effor, as it will help on speeds slower than 115k baud.
I think I got close but don't get a correct picture. I think the error is on the decoding side. But I don't get it. Maybe if I look at it later again.
(Still l and one char variables in, as it's the old code. The newly added variable names are better. :-))
encoding:
//*pbuf is the pointer to the 32 byte RGB pixel buffer
           void rgbTo4Bit (byte *pbuf, int bufflength){
for (unsigned int l= 0; l < bufflength/4; ++l){
int msbLeft = pbuf[4*l] & 0xff;
int lsbLeft = pbuf[4*l+1] & 0xff;
int rLeft = (lsbLeft >> 3) & 0x1F;
int gLeft = ((lsbLeft & 0x07) << 3) | ((msbLeft >> 5) & 0x07) ;
int bLeft = (msbLeft & 0x1f);
rLeft = rLeft << 2;
gLeft = gLeft << 1;
bLeft = bLeft << 2;
int grayLeft=(77 * rLeft + 150* gLeft + 29 * bLeft) >> 8;
grayLeft = grayLeft >> 4;
grayLeft = grayLeft << 4;
int msbRight = pbuf[4*l+2] & 0xff;
int lsbRight = pbuf[4*l+3] & 0xff;
int rRight = (lsbRight >> 3) & 0x1F;
int gRight = ((lsbRight & 0x07) << 3) | ((msbRight >> 5) & 0x07) ;
int bRight = (msbRight & 0x1f);
rRight = rRight << 2;
gRight = gRight << 1;
bRight = bRight << 2;
int grayRight=(77 * rRight + 150* gRight + 29 * bRight) >> 8;
grayRight= grayRight >> 4;
pbuf[l]=(grayLeft | grayRight);
decoding (in Processing):
for (int row = imageh-1; row >= 0; --row)
  for (int col = 0; col < imagew; col=col+2)
    int loc = imagew*row+col;
          int LeftPixel= packedbuf[loc] >>> 4;
          LeftPixel= LeftPixel << 4;
          int RightPixel= packedbuf[loc] << 4;
          img.pixels[loc] = color(LeftPixel,LeftPixel, LeftPixel);
          img.pixels[loc+1] = color(RightPixel, RightPixel, RightPixel);
It loos like this: http://picturepush.com/public/11920881
Must be something wrong with the col and row count I think,
Robert
robtillaart
decoding:
  for (int col = 0; col < imagew; col += 2)
    int loc = imagew*row + col;
    int LeftPixel = packedbuf[loc] & 0XF0;  // mask the higher 4 bits is enough
    int RightPixel = packedbuf[loc] << 4;
Rob Tillaart
robtillaart
#20
Jan 09, 2013, 07:28 pm Last Edit: Jan 12, 2013, 02:42 pm by robtillaart Reason: 1
For encoding the 4 bit you can reuse your rgb2gray() because that almost delivers the right thing
somewhere in the code just add one line - in the download code where you patched the rgb buffer to gray
  rgb2gray(buffer, length);
  gray2doublegray(buffer, length/2);  // adjust params
void gray2doublegray(byte *buf, int len)
 int pos = 0;
 for (int i = 0; i < len; i += 2)
   int packed = buf[i] & 0xF0;
   packed += (buf[i+1] & 0xF0) >> 4;
   buf[pos++] = packed;
get the idea? give it a try
Rob Tillaart
robvoi
Reusing the grb2gray function is indeed much more elegant. Same goes for the masking, which should also be more efficient.
I still have a problem with the decoding/placing the pixels (I think that's wher the problem is.). I found one bug and it looks better now. But it's still not correct.
I started a thread in the Processing forum about this specific topic.
https://forum.processing.org/topic/writing-pixels-to-a-pimage-positioning-pixels-right
Robert
robtillaart
Reusing the code makes it more modular and you could make one download function that depending on the parameter from processing it returns either colour, gray or doublegray
Rob Tillaart
robvoi
Hi robtillaart,
got the 4bit part now working too.
encoding:
int grayLeft=pbuf[A] & 0xF0;
int grayRight=(pbuf[A+1] & 0xF0) >> 4;
pbuf[pos]=(grayLeft | grayRight);
decoding:
int LeftPixel = packedbuf[loc/2] & 0xF0;
int RightPixel = (0x0F & packedbuf[loc/2]) << 4;
img.pixels[loc] = color(LeftPixel, LeftPixel, LeftPixel);
Regarding to 5/6 bit to 8 bit transcoding:
until now I used:
r = r << 2;
g = g << 1;
b = b << 2;
you suggested (gived the black areas):
r = r << 3;
g = g << 2;
b = b << 3;
The processing code uses:
r = (r << 3)|(r >>> 2);
g = (g << 2)|(g >>> 4);
b = (b << 3)|(b >>> 2);
I now use:
r = (r << 2)|(r >> 1);
g = (g << 1)|(g >> 3);
b = (b << 2)|(b >> 1);
This gives quite good results. I still don't understand why I have to shift one bit less than even the Processing code does.
At least it works.
Robert
robtillaart
How about the performance?
And quality of the images (good enough)?
Rob Tillaart
robvoi
The performance is good. Bit below 8bit the calculation time eats the time gain in transmition. At least with 115k baud. With less transmition speed the 4 and 2 bit options become interesting.
The quality is ok, but not good.
I think the 8 bit grayscale is only 7 bit (so only contains 127 color shades). If I go down further, so 4 or 2 bit I need to shift different at the initial RGB to grayscale convertion.
Otherwise I get black blocks.
I now have a rgb28bit function where I shift
and a rgb28bit_low function (to be used for rgb to 4 or 2 bit)
r = (r << 3)|(r >> 2);
g = (g << 2)|(g >> 4);
b = (b << 3)|(b >> 2);
All a bit strange.
robtillaart
YOu can speed up the code by going though the code you changed and look where you can replace 16 bits ints with 8 bits ones. Remove temporary vars.
As the same math is done for every pixel this adds up. Furthermore you can do more in place
e.g.
void gray2doublegray(byte *buf, byte len)
  byte pos = 0;
  for (byte i = 0; i < len; i += 2)
    buf[pos++] = (buf[i] & 0xF0) |( (buf[i+1] & 0xF0) >> 4);
Rob Tillaart
robvoi
Thanks for the advice. I'll go through the code an see what can be changed.
I hope the Hcrocam guys are able to solve the shifting puzzle. I would like to have it as it is supposed to be.
They were interested int eh work. So they may come by after their vacation.
robtillaart
does   img.pixels[loc] = LeftPixel;   work? [processing]
Rob Tillaart
robvoi
no, this doesn't work. It doesn't give a picture at all.
The image is defines as:
PImage img = createImage(imagew, imageh, RGB);
So I think it expects three values. Possible formats are RGB, ARGB and APLHA.
