Topic: connecting two common ground on the breadboard to one on arduino? (Read 6130 times) previous topic - next topic
A4kash
Jan 06, 2013, 06:20 pm Last Edit: Jan 06, 2013, 07:28 pm by A4kash Reason: 1
Since i am a newbie,i have a problem regarding joining two common ground on the board.In this case the first led is connected to ground and some pin no. but the 2nd and third led,their anodes are connected to the pin nos. on the arduino board but their cathode is just left on the ground rail on the breadboard.What i am confused is can we connect these two ground from 2nd and 3rd led with the 1st led?
codlink
//LiNK
larryd
To start with, draw a schematic diagram of the circuit you are talking about. This helps to visualize whats happening.
For review: http://www.kpsec.freeuk.com/components/led.htm &
http://www.kpsec.freeuk.com/symbol.htm
No technical PMs.
The last thing you did is where you should start looking.
Docedison
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
fungus
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
codlink
No, all grounds MUST be connected.
lol, true, but can think of instances where you shouldn't, but that's for another discussion..
Like Larry said, we need a schematic of your setup to help in more detail.
//LiNK
A4kash
here ground fromarduino is not connected with the grounds from two leds...
larryd
I am having some trouble understanding.
The cathodes of all the LEDS can share a common ground point on a breadboard.
No technical PMs.
A4kash
Even without connecting common ground it worked and i am wondering how this circuit worked!!!Having problem in it....
fungus
Grab a multimeter and you can measure the difference between the grounds. Maybe you got lucky and it wasn't enough difference to burn out your LEDs or Arduino.
But don't depend on it. One day the magic smoke WILL come out of your components if you don't use common ground.
A4kash
A4kash
