Loading...
Pages: 1 [2]   Go Down
Author Topic: serial output corruption with ethernet arduino  (Read 539 times)
Offline Offline
Newbie
View Profile
Thank you for the info. I'll look ASAP
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Just what are you trying to do? Are you sending a get request to a server and trying to capture data from what is sent from the server?
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
Sending the GET command to the head unit. Then relay data to remote server. That server remotely displays data on a portal. But this code just sends GET then converts to the string output to relay it to the remote server.
« Last Edit: January 04, 2013, 01:51:25 pm by drewpalmer04 » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
If you are trying to pass a lot of html churn, then you might consider saving all the html text to an SD card, then sending the captured material from the SD card to the remote server.
Logged
Offline Offline
Newbie
View Profile
Well it's not my server. I'm just trying to send the string to the server to display my data but the string gets corrupted at the end as seen in my above example
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
just how big is the string?
Logged
Offline Offline
Newbie
View Profile
<RA><T1>804</T1><T2>698</T2><T3>773</T3><PH>862</PH><R>248</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>84</PWMA><PWMD>76</PWMD></RA>
This is the entire string...it repeats over and over and changes the values depending on what the serial receives from the headunit for values. IE:<T1>804</T1> can be the temperature reading that can change to 805 709 etc etc.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You may need to check the http specs for query_string length limits. Might be something like 128 characters. longer than the limit you might need to use a post method.
Logged
Offline Offline
Newbie
View Profile
You said that you have a sketch that just reads the serial data. So, after reading up the \n, how many characters are in the array? The readBytesUntil() method NULL terminates the array, so strlen() will tell you the length.
I'm sorry  but I can't get this function to work...could you lay it out in my code for me? So I can get an answer for you...Sorry I'm a noob
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Code:
      int b=Serial.readBytesUntil('\n',strout,sizeof(strout));
   int len = strlen(strout);
Of course, you could just print the value in b, instead. It should contain the same value as len.
Logged
Offline Offline
Newbie
View Profile
issue resolved...thank you for everyone's help.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
