I´ve done two sketches, one for a sensor and another one for a servo. But i don´t know if a can mix them in one sketch so i can use just one Arduino. Thanks a lot.
This is the sensor´s code: (it´s an easy one)
const int SENSOR = 0;
int val = 0;
void setup () {
void loop () {
val = analogRead (SENSOR);
Serial.println (val);
delay (100);
And this servo´s:
#include <Servo.h>
Servo servoMain; // Define nuestro servo
servoMain.attach(10); // servo en pin 10PWM
servoMain.write(45); // Gira 45 grados
delay(1000); // espera un segundo
servoMain.write(0); // gira 0 grados
servoMain.write(90); // gira al centro, 90 grados
servoMain.write(135); // gira 135 grados
servoMain.write(180); // gira 180 grados
I´ve tried to mix them apparently in a correct way but when i open Processing the sensor doesn´t run. Thank you very much again.
Moderator edit: Replaced italics tags with CODE TAGS
