Loading...
Pages: [1]   Go Down
Author Topic: I bought a battery  (Read 556 times)
Offline Offline
Sr. Member
View Profile
I just bought a 30 amp an hour 12 volt lead acid battery for my large robot.
-what should I know about the battery to help the battery live to it's longest life span.
another question, What kind of voltage drop will happen when I put a load on the battery?
how low will the voltage go with a 10 amp drain on the battery?
Logged
Cape Town South Africa
Offline Offline
Edison Member
A newbie with loads of posts, and still so much to learn !
View Profile
WWW
Is it a deep cycle battery ?
Logged
We live in the era of the smart phones and stupid people.
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
No it's probably from a car
 smiley-cool
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Offline Offline
Sr. Member
View Profile
it says on the side
AGM sealed lead acid battery. non spillable
brand: Werker
I bought it at battery plus
Logged
Offline Offline
Edison Member
View Profile
WWW
Its probably a car type battery, I am no expert but I think you must keep it charged to 11 volts or so, or the lead or zinc in the plates starts desintegrating.
The deep cycle ones have something to avoid this, but it limits the current ?
Google deep cycle battery.
Logged
Australia
Offline Offline
Sr. Member
Arduino rocks
View Profile
The best way to look after them is to keep them topped up with charge. The fewer and less deep the cycles, the longer they will last. They have no memory effect and therefore frequent charges are not detrimental to their performance. To maximise teir life, its best not to let their voltage drop below 12 volts however serious damage will not occur unless you let them go below 10 volts for any length of time, when sulfation occurs.
Quote
Depends on the load.
I would not expect anything more than a minor (0 - 0.5 volts) drop on a fully charged 30 Ah lead acid battery that is in reasonable condition.
Logged
Phoenix, Arizona USA
Online Online
Faraday Member
Where's the beer?
View Profile
WWW
That battery is an SLA - and are typically used for UPS purposes; I am pretty sure most SLA batteries are "deep cycle". That said, all that's needed to be done is to keep it charged up, and not let it sit without periodic charging (or put it on a smart trickle charger to keep it topped up).
Logged
New River, Arizona
Offline Offline
God Member
Arduino rocks
View Profile
WWW
Supposedly, you should be able to get 10 amp continuously out of it for 3 hours, hence 30 amp/hour.  Practically, it will drop in voltage over the period such that the device it hooks to will stop working at some point.  These deep discharge batteries are tough and can take being discharged down quite a bit and not sustain damage; especially the AGM cells.  You don't have to worry about adding water or it spilling when the robot flips over, but don't leave it on it's side or upside down for a long time; especially if it is charging.  There is a vent on it somewhere to release gasses, and if it's upside down and charging, it may leak fluid due to gas pressure.  Don't leave it fully discharged for very long (measured in days) or it will damage the cell.
Deeply discharged AGM batteries take a longer time to charge and require a lower charge current than 'regular' lead acid.  If you check the manufacturer's web site (if you can find it) they will show recommended maximum charge current.  The charge current is a function of cell area so it varies.  Many AGM batteries recommend 13.4-13.6 VDC float to maintain charge and not damage the battery.  You can find chargers that do this, or just get an lm317 and hook it up.
Yes, I have a few of them.
Logged
Trying to keep my house under control http://www.desert-home.com/
Offline Offline
Sr. Member
View Profile
I got a 2 amp schumacher sc-200A
the guy at battery plus recommended it.
I also have a smaller lead acid charger but it says .5 amps and only charge batteries smaller than 17 amps an hour.
will the sc-200A charger be too fast?
Logged
New River, Arizona
Offline Offline
God Member
Arduino rocks
View Profile
WWW
That's a nice charger.  I haven't used that particular one, but it has all the features you need to take care of the battery.  Don't expect the battery to charge up quickly though; this kind of battery takes a charge far slower than it delivers.  You'll have to experiment a bit to see how long it will supply power for you, but I think you'll like it.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Roughly you charge lead acid batteries at a rate no more than 1/10th their capacity for optimum lifetime. So your 30Ah battery would be charged at 3A. But the charge rate is not as important as avoiding discharging or 50% or leaving it sit off a charger for months at a time.
It's also worth noting that a sealed battery is charged to a different float voltage than a flooded (car) battery. Your charger offers no ability to choose the battery type; a slightly more expensive charger would.
Good reading for a similarly sized AGM battery showing how discharge level/rate affects battery life.
Logged
Pages: [1]   Go Up
Print
Jump to:
