thnx for the reply, however i have a problem with some code.
i looked at this tutorial:
http://www.instructables.com/id/3X3-LED-Cube-Programming-tips-Arduino-based/this looks really easy to make patterns, if it works.
when i want to upload the code:
Based on ledcube.c from Make: September 7, 2007 weekend podcast
http://blog.makezine.com/archive/2007/09/make_a_pocket_led_cube_we.html
Custom animation programmed by Mark Boszko, http://stationinthemetro.com
#include <avr/pgmspace.h> // allows use of PROGMEM to store patterns in flash
#define CUBESIZE 3
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 5 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
prog_uchar PROGMEM PatternTable[] = {
B101, B010, B101, B000, B000, B000, B000, B000, B000, 50 ,
B000, B000, B000, B000, B010, B000, B000, B000, B000, 50 ,
B000, B000, B000, B000, B000, B000, B101, B010, B101, 50 ,
** Defining pins in array makes it easier to rearrange how cube is wired
** Adjust numbers here until LEDs flash in order - L to R, T to B
** Note that analog inputs 0-5 are also digital outputs 14-19!
** Pin DigitalOut0 (serial RX) and AnalogIn5 are left open for future apps
//int LEDPin[] = {16, 3, 1, 15, 4, 6, 14, 5, 7};
int LEDPin[] = { 2, 3, 4, 5, 6, 7, 8, 9, 10};
//int PlanePin[] = {19, 18, 17};
int PlanePin[] = {13, 12, 11};
// initialization
int pin; // loop counter
// set up LED pins as output (active HIGH)
for (pin=0; pin<PLANESIZE; pin++) {
pinMode( LEDPin[pin], OUTPUT );
// set up plane pins as outputs (active LOW)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
// display pattern in table until DisplayTime is zero (then repeat)
// declare variables
byte PatternBuf[ PLANESIZE ]; // saves current pattern from PatternTable
int PatternIdx;
byte DisplayTime; // time*100ms to display pattern
unsigned long EndTime;
int plane; // loop counter for cube refresh
int patbufidx; // indexes which byte from pattern buffer
int ledrow; // counts LEDs in refresh loop
int ledcol; // counts LEDs in refresh loop
int ledpin; // counts LEDs in refresh loop
// Initialize PatternIdx to beginning of pattern table
PatternIdx = 0;
// loop over entries in pattern table - while DisplayTime>0
do {
// read pattern from PROGMEM and save in array
memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE );
PatternIdx += PLANESIZE;
// read DisplayTime from PROGMEM and increment index
DisplayTime = pgm_read_byte_near( PatternTable + PatternIdx++ );
// compute EndTime from current time (ms) and DisplayTime
EndTime = millis() + ((unsigned long) DisplayTime) * TIMECONST;
// loop while DisplayTime>0 and current time < EndTime
while ( millis() < EndTime ) {
patbufidx = 0; // reset index counter to beginning of buffer
// loop over planes
for (plane=0; plane<CUBESIZE; plane++) {
// turn previous plane off
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], LOW );
digitalWrite( PlanePin[plane-1], LOW );
// load current plane pattern data into ports
ledpin = 0;
for (ledrow=0; ledrow<CUBESIZE; ledrow++) {
for (ledcol=0; ledcol<CUBESIZE; ledcol++) {
digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
patbufidx++;
// turn current plane on
digitalWrite( PlanePin[plane], HIGH );
// delay PLANETIME us
delayMicroseconds( PLANETIME );
} // for plane
} // while <EndTime
} while (DisplayTime > 0); // read patterns until time=0 which signals end
then i get this errors:
sketch_jan07a:34: error: expected ',' or ';' before 'int'
sketch_jan07a.ino: In function 'void setup()':
sketch_jan07a:45: error: 'LEDPin' was not declared in this scope
sketch_jan07a.ino: In function 'void loop()':
sketch_jan07a:95: error: 'LEDPin' was not declared in this scope
what can be the problem?
