Topic: Fload value (Read 949 times) previous topic - next topic
Midway
hi all,
i have made:
Code: [Select]
lcd.setCursor(0, 1);
    int AFCvalue = analogRead(A1);               // Read the AFC input on analog pin 1:
    float AFC = AFCvalue * (4.5 / 1023.0);       // Convert the AFC value (which goes from 0 - 1023) to a voltage (0 - 5V)
   if (AFC>2)                                    // A videosignal wil be present higher then 2 volts!
    digitalWrite(Lockled, HIGH);                 // Turn Lock LED "ON" when Tuner are Locked on frequency
    lcd.setCursor(0,0);
    lcd.print("  L ");
    lcd.print(AFC);
    delay(dt);
    digitalWrite(Lockled, LOW);                  // Turn Lock LED "OFF" when Tuner have no signal
    lcd.setCursor(0,0);
    lcd.print("  U ");
    lcd.print(AFC);
    delay(dt);
The output on the LCD "2,38" volt.
My project need a more specific value. example 2,3875 volt. So 4 or maybe 5 digits more are exacter.
what code can i use to make this working?
Edwin
Grumpy_Mike
You need better hardware to get more precession from an A/D converter.
Midway
thx :(
retrolefty
Adafruit carries a couple of nice I2C ADC modules that will give much higher resolution results then the internal ADC does:
https://www.adafruit.com/products/1083
http://www.adafruit.com/products/1085
Midway
ah, this is great.
thanks
gardner
Code: [Select]
    lcd.print(AFC);
If you just want to see more decimal places on your display, do:
Code: [Select]
    lcd.print(AFC,4);
Of course, as other have pointed out, the extra decimals really mean nothing since the ADC on the Arduino is not that accurate.  The best you could hope for is about 1 part in 500 accuracy, on a good day, with the wind in the right direction and all that.  And the 3-figure output you've already gotten is more than good enough to represent that.
dhenry
Quote
You will need to look into lcd.print() and see if / how you can specify more digits.
Midway
Code: [Select]
lcd.print(AFC,4);
this is what I'm looking for.
shame myself, i must know this.
text12
Code: [Select]
    lcd.print(AFC,4);
That works great! is there a way to turn off the rounding?
For example I have a float 118.225, I only want to display the first 2 decimal places but lcd.print(COM1A); returns 118.23.
PaulS
Quote
Write your own function. Not rounding is not a good idea. Why do you want to do that?
text12
Quote
I'm simulating an aviation radio. 118.225 is a communication frequency. The 3rd decimal place is used for tuning calculation but is not displayed to the pilot. So on my LCD I need it to say COM1 = 118.22 , but when I turn my rotary encoder I'm adding .025 to the frequency. So I need to keep the 3 decimal precision but only display the first 2.
PaulS
Quote
Then, you'll need to write your own function.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
