Topic: crc16 supplied code (Read 4134 times) previous topic - next topic
willievmobile
hey guys,
i started a project a little while ago with some UHFreaders which im using to get into Arduino...
Ive run into a few problems but slowly im working my way thru them.
at the moment im having trouble grasping the crc16 check sum that i have to send and receive every time i communicate with the reader.
Here is the code from the protocol manual:
#define PRESET_VALUE 0xFFFF
#define POLYNOMIAL 0x8408
unsigned int uiCrc16Cal(unsigned char const * pucY, unsigned char ucX)
  unsigned char ucI,ucJ;
  unsigned short int uiCrcValue = PRESET_VALUE;
  for(ucI = 0; ucI < ucX; ucI++)
    uiCrcValue = uiCrcValue ^ *(pucY + ucI);
    for(ucJ = 0; ucJ < 8; ucJ++)
      if(uiCrcValue & 0x0001)
        uiCrcValue = (uiCrcValue >> 1) ^ POLYNOMIAL;
        uiCrcValue = (uiCrcValue >> 1);
  return uiCrcValue;
Which i can paste into arduino and it compiles. But when i try and call the function i cant compile:
unsigned char const * cardno = 7;
   unsigned short int reply = uiCrc16Cal(cardno,6); //here im guessing its the dataarray and length that i need to send???
the card number i have is 07 00 EE 00 A2 B4 89 61
(just a breakdown 07 is the length , 00 reader address , EE is tht command , 00 is status , A2 and B4 is the data , 89 and 61 are the CRC16 check sums LSB-CRC16 and MSB-CRC16. so i can use this to double check my crc calculations...
ive read for more than a week while doing my lcd,rtc and sd card code all which ive managed :D but the reader communication is killing my last braincells/...
oh on the LCD i have a tm1638 and its working great, but what would be the best way of making a menu structure? ive looked into menwiz but doesnt look like it will support the tm1638. at the moment i just have a bunch of strings in an array but that is very heavy on ram(from what ive read) any ideas?
any help is appreciated .
thanks
W
MarkT
You are trying to set a variable of char * type to 7.  7 is an integer, not a pointer-to-char.
Why not something like
void whatever ()
  unsigned char buffer [BUFLEN] ;
  .. put stuff in buffer
  unsigned int reply = uiCrc16Cal (buffer, BUFLEN) ;
  .. use the crc...
In Arduino you don't need to say "short" as ints are already 16 bit.
Personally I'm not a fan of verbose coding style with types encoded in the variable names, and that
function is probably a lot easier to understand rewritten more concisely with better var names:
unsigned int uiCrc16Cal (byte * buf, byte len)
  unsigned int crc = PRESET_VALUE ;
  for (byte i = 0; i < len; i++)
    crc ^= buf [i] ;
    for (byte j = 0; j < 8; j++)
      unsigned int feedback = (crc & 0x0001) == 0 ? 0 : POLYNOMIAL ;
      crc = (crc >> 1) ^ feedback ;
  return crc ;
robtillaart
you can also consider using - http://www.nongnu.org/avr-libc/user-manual/group__util__crc.html -
Rob Tillaart
dhenry
Your code is correct. You just aren't passing the correct parameters to it.
nickgammon
Do you mean:
unsigned char const * cardno = "7";
Your code had the address of a pointer to who-knows-what at address 7.
willievmobile
#5
Jan 07, 2013, 07:08 pm Last Edit: Jan 07, 2013, 08:11 pm by willievmobile Reason: 1
Thanks Guys for the fast responses,
im happy the code is right i actually tried sending a array must have done something stupid (as usual).....
Thanks mark i agree your code looks better and easier to read :)
void whatever ()
  .. use the crc...
    crc ^= buf [i] ;
  return crc ;
ok sorry i know i read in some books i must put it in "" totally slipped my mind thank you!!
Do you mean:
Thank you Rob, i have looked at that and i wasnt sure if that is the same as this(or would compute the same  :smiley-eek-blue:
ok now to get working again :)
Thanks everyone ill report back how it goes :D
regards
Willie
robtillaart
CRC-16 == CRC-16  but implementations can have bugs ...
Rob Tillaart
willievmobile
#7
Jan 07, 2013, 08:52 pm Last Edit: Jan 07, 2013, 08:55 pm by willievmobile Reason: 1
EDIT: Thanks Rob you posted while i was writing this :)
EDIT2: oh just remembered i cant test if the crc works right with the reader as im still waiting for my serial -TTL converters...
oh but its fun when your a blond!!!
Hey Guys ,
Just an update.. its working!!!!!!!!
tried it with this card number : 07 00 EE 00 29 15 6E BD
used a buffer (just hard coded to see if it works):
   buffer[0]=0x07;
   buffer[1]=0x00;
   buffer[2]=0xEE;
   buffer[3]=0x00;
   buffer[4]=0x29;
   buffer[5]=0x15;
   buffer[6]=0x6E; // is this the LSB crc16 ?????
and got a crc of BD6E which is the last two bytes of the card number backwards (as i believe it should be) swaped is 6E and BD.
Which is GREAT :D
but
..(dont you just hate buts!)
maybe im understanding the documentation incorrectly (English is not my native tongue)
the documentation says when sending ill need something like:
command:
Len , Adr ,  Cmd , Data[] , LSB-CRC16 , MSB-CRC16.
response is :
Len , Adr , reCmd , Status , Data[] , LSB-CRC16 , MSB-CRC16
so how can i calculate the LSB-CRC16 ? as i used that in to do the crc calculation?
or am i wrong and i just do the crc calc on Len, Adr , Cmd and Data[] ?
i think that should give me 2 bytes and use them as the last 2 bytes to be sent?
Im guessing im wrong so will start sending data to the reader to see if it works :smiley-roll-sweat:
Again any insight is happily received.
Thanks
Willie
robtillaart
depends, if the first sentence before the but is negative ....
int x = do_crc-16();
byte lsb = x & 0xFF;
byte msb = x >> 8;
this one
Rob Tillaart
willievmobile
:P agreed
byte msb = x >> 8;
this one
Thank you Rob, ill be doing most of the code i can for the menus ect to try and be as finished as i can when my converters come
if anyone has i idea which menu lib works with the TM1638 module feel free to save me a lot of work trying to make my own ;)
Thanks again for everyone's help !!!
Willie
dhenry
There are plenty of tests for crc routines.
A simpler way, however, is the append the crc checksum to the end of the original message and recalculate the crc on the expand message (=original message + 2 bytes).
The checksum for the expanded message should be zero.
