Loading...
Pages: [1]   Go Down
Author Topic: Tombstones on Due  (Read 901 times)
Offline Offline
Newbie
View Profile
On 2 of 4 Due's I had Tombstones (wrong soldered SMD-Devices, stand up instead lie flat), if your Due has a strange behavior take a look.
Btw, why is the wire an sinuous line like a snake, shall it be an inductance ?
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
Quote
 Just a guess, maybe it is to help make the traces the same overall length. I have read that with high speed devices that trace length is important.
Logged
St. Petersburg, FL
Offline Offline
Jr. Member
Retired physicist
View Profile
WWW
Trace length is important only at very high frequencies. The Due is not in that category. Serpentine traces are used to help anchor the copper to the board. Line straight lines tend to lift if they experience a temperature change. Think of it as expansion joints.
Logged
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
well that never should have made it to you. Somewhere in QA it should have been rejected. That's caused by poor paste distribution, improperly placed component or some similar problem in the manufacturing process.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Correct. In general the Due does not have any high-speed signals but the USB D- and D+ might be an exception, which is what you are seeing here.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Greenville, IL
Offline Offline
Edison Member
View Profile
 Cool! I got one right!
 Thanks for your input Graynomad. I still think one of your designs for the Atmel Arm chip would be great to see!
Logged
Offline Offline
Tesla Member
View Profile
WWW
It's in the works, we're going over the mechanical and electrical design as we speak.
Just to give you a hint, fits a standard enclosure, support for EMAC (RMII ethernet), I2S (codecs), HSMCI (fast SD cards), 24 PWM, 8 native analog inputs, 8-bit 8MB external memory, 2x CAN, up to 8 addressable daughter boards with quasi-vectored interrupts, control over various power options, and hopefully reasonable legacy shield support.
Some of this is a bit above my pay grade but the basic design is done and it looks doable.
______
Rob
Logged
Greenville, IL
Offline Offline
Edison Member
View Profile
  Nice to know your board still has a chance to live! Sounds like it is going to have nearly anything a person could possibly want!
Logged
Offline Offline
Tesla Member
View Profile
WWW
Watch this space. We should shave some nice features.
______
Rob
Logged
Pages: [1]   Go Up
Print
Jump to:
