Loading...
Pages: 1 ... 5 6 [7] 8 9   Go Down
Author Topic: Need some help for a science project.  (Read 3171 times)
Offline Offline
Jr. Member
View Profile
This is all so confusing, but it has to get done...
Logged
Robots are cool.
UK
Offline Offline
Tesla Member
View Profile
After seven pages I've lost track of what you have got working, and where you're stuck.
What's the current problem?
Logged
Offline Offline
Jr. Member
View Profile
It's cool. Here's where I am right now... I built the hand itself, but I need to get multiple servo's running at once, so I can tie the strings on the fingers into the holes in the servo motor and I'm having some trouble getting 1 to run on external power.
Logged
Robots are cool.
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Here's my suggestion then:
1- Put DuaneB's multi servo sketch aside for now.
2- Reload sweep, which I think u said was working before?
3- Carefully check the wiring* of the one servo, your Fritzing pic showed you had the red and black confused. Keep the Arduino powered from the PC...
4- Run sweep to verify that the servo runs from external power.
5- Then and only then, edit sweep along the lines of my suggestion many posts back, to have a second servo ("myOtherServo" for instance) on another pin and run that new sketch to verify two servos
Then we'll talk some more...
* wiring is battery +ve to servo red, -ve to servo black and also Arduino ground, yellow / orange to Arduino pin to which servo is attached in sketch. Check the voltage is what the servo needs, probably 4.8 to 6, not the 9 you were using
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Something along the lines of the Fritz attached
Logged
IT Crowd:
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
And two would be thus....
Make sure the yellow wires go to the pins you attach the servos to in the skecth
Logged
IT Crowd:
Offline Offline
Jr. Member
View Profile
Will a battery holder that can hold 6 batteries work with only 4 inside?
Logged
Robots are cool.
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Not normally, no
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Jr. Member
View Profile
Thanks. It works fine with 6.  smiley
Logged
Robots are cool.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Only if you jumper out the two empty spaces with a soldered jumper wires, or find solid brass rods of the same size as the batteries to use as 'dummy cells'.
Lefty
Logged
Offline Offline
Jr. Member
View Profile
Hmmm... I got one servo running from external power on pin 9, but the code I tried to write (newbie programmer here) doesn't seem to work. I looked at the reference library on the Arduino website too.
Logged
Robots are cool.
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
That's sad.
(Hint)
Logged
Offline Offline
Jr. Member
View Profile
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Logged
Robots are cool.
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
OK, so what does it do that it shouldn't and what doesn't it do that it should?
Code tags would be good too.
Logged
Offline Offline
Jr. Member
View Profile
It doesn't move at all when I upload it.
Logged
Robots are cool.
Pages: 1 ... 5 6 [7] 8 9   Go Up
Print
Jump to:
