Pages: 1 ... 4 5 [6] 7 8 9   Go Down
Author Topic: Need some help for a science project.  (Read 3142 times)
So I tried to do sweep with my Uno, and it decided that it does not want to work anymore, so now I have to do a completely different science project.
Robots are cool.
I also have an extra that I haven't touched at all and that isn't working either.
Robots are cool.
Beijing
Skype name habib.derbyshire
Aw... Sorry to hear that. Don't drop Arduino now you've picked it up though...
What is man's best friend? The breadboard!
Nevermind. It was a false alarm.  smiley-roll
Robots are cool.
However, one of them did die on me. Whenever I plug the USB in, the green LED turns on and then immediately turns off.
Robots are cool.
Beijing
The led on the servo, on the computer or on the Arduino? If it's on the Arduino, there's a short circuit and you must be very careful or you might destroy your Arduino.
The Arduino.
Robots are cool.
Beijing
The green led? YOu mean the TX and RX leds?
Yeah, that's what I'm talking about. It started working again though.
Robots are cool.
Beijing
The TX and RX leds only flash when your uploading a sketch.
Woops. I actually meant the ON LED.  smiley-roll
Robots are cool.
Beijing
You must be careful when that happens. It means there's a short circuit somewhere.
This is getting out of hand... I'm doing everything it says in this tutorial, (http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html) and it still isn't working... I have to have this thing done by February 4th, and this is worth a TON of points, so if it doesn't get done, my grade will suffer...
Robots are cool.
Wait a second... How do I add a servo? Here's the line of code.
  // attach the servos
  for(int nServo = 0;nServo < CONNECTED_SERVOS;nServo++)
    myServos[nServo].attach(SERVO_TO_PIN(nServo));
Robots are cool.
Johannesburg UTC+2
At the top of DuaneB's code it says this...
#include <Servo.h>
// Sample sketch for driving 12 Servos from an Arduino UNO, servos are attached to digital pins 2,3,4,5,6,7,8,9,10,11,12,13
#define CONNECTED_SERVOS 12
It sweeps a whole load of servos on those pins....
So to attach servos to the board, you control them by putting their yellow / orange wires into those pins.
(The #define CONNECTED_SERVOS 12 tells it there are 12 and you could reduce that number I guess to just have however servos you have)
This part:
... uses the value of "CONNECTED_SERVOS" which is 12 if you didn't alter it at the top as the upper limit of a counter in a loop and runs the "attach" line as many times as you have servos to as many pins as there are servos.
This is an automated way of doing what I showed you a few posts back where I had something like myservo.attach and anotherservo.attach. The myServos[nServo] in Duane's code is a way of automating say myServos5 and myServos9 or whatever where nServo is a variable instead of hardcoding the same line a stack of times each with a different number.
« Last Edit: January 26, 2013, 12:13:53 am by JimboZA » Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Pages: 1 ... 4 5 [6] 7 8 9   Go Up
