Topic: Need some help for a science project. (Read 27734 times) previous topic - next topic
Falchion
This is all so confusing, but it has to get done...
PeterH
After seven pages I've lost track of what you have got working, and where you're stuck.
What's the current problem?
Falchion
It's cool. Here's where I am right now... I built the hand itself, but I need to get multiple servo's running at once, so I can tie the strings on the fingers into the holes in the servo motor and I'm having some trouble getting 1 to run on external power.
JimboZA
Here's my suggestion then:
1- Put DuaneB's multi servo sketch aside for now.
2- Reload sweep, which I think u said was working before?
3- Carefully check the wiring* of the one servo, your Fritzing pic showed you had the red and black confused. Keep the Arduino powered from the PC...
4- Run sweep to verify that the servo runs from external power.
5- Then and only then, edit sweep along the lines of my suggestion many posts back, to have a second servo ("myOtherServo" for instance) on another pin and run that new sketch to verify two servos
Then we'll talk some more...
* wiring is battery +ve to servo red, -ve to servo black and also Arduino ground, yellow / orange to Arduino pin to which servo is attached in sketch. Check the voltage is what the servo needs, probably 4.8 to 6, not the 9 you were using
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
JimboZA
Something along the lines of the Fritz attached
JimboZA
And two would be thus....
Make sure the yellow wires go to the pins you attach the servos to in the skecth
Falchion
Will a battery holder that can hold 6 batteries work with only 4 inside?
AWOL
Falchion
retrolefty
Only if you jumper out the two empty spaces with a soldered jumper wires, or find solid brass rods of the same size as the batteries to use as 'dummy cells'.
Lefty
Falchion
Hmmm... I got one servo running from external power on pin 9, but the code I tried to write (newbie programmer here) doesn't seem to work. I looked at the reference library on the Arduino website too.
AWOL
That's sad.
(Hint)
Falchion
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
AWOL
OK, so what does it do that it shouldn't and what doesn't it do that it should?
Code tags would be good too.
Falchion
It doesn't move at all when I upload it.
