Pages: 1 ... 5 6 [7] 8 9   Go Down
Author Topic: Need some help for a science project.  (Read 3173 times)
This is all so confusing, but it has to get done...
Robots are cool.
UK
After seven pages I've lost track of what you have got working, and where you're stuck.
What's the current problem?
It's cool. Here's where I am right now... I built the hand itself, but I need to get multiple servo's running at once, so I can tie the strings on the fingers into the holes in the servo motor and I'm having some trouble getting 1 to run on external power.
Robots are cool.
Johannesburg UTC+2
Here's my suggestion then:
1- Put DuaneB's multi servo sketch aside for now.
2- Reload sweep, which I think u said was working before?
3- Carefully check the wiring* of the one servo, your Fritzing pic showed you had the red and black confused. Keep the Arduino powered from the PC...
4- Run sweep to verify that the servo runs from external power.
5- Then and only then, edit sweep along the lines of my suggestion many posts back, to have a second servo ("myOtherServo" for instance) on another pin and run that new sketch to verify two servos
Then we'll talk some more...
* wiring is battery +ve to servo red, -ve to servo black and also Arduino ground, yellow / orange to Arduino pin to which servo is attached in sketch. Check the voltage is what the servo needs, probably 4.8 to 6, not the 9 you were using
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Johannesburg UTC+2
Something along the lines of the Fritz attached
IT Crowd:
Johannesburg UTC+2
And two would be thus....
Make sure the yellow wires go to the pins you attach the servos to in the skecth
IT Crowd:
Will a battery holder that can hold 6 batteries work with only 4 inside?
Robots are cool.
UK
Not normally, no
Thanks. It works fine with 6.  smiley
Robots are cool.
Left Coast, CA (USA)
Online Online
Measurement changes behavior
Only if you jumper out the two empty spaces with a soldered jumper wires, or find solid brass rods of the same size as the batteries to use as 'dummy cells'.
Lefty
Hmmm... I got one servo running from external power on pin 9, but the code I tried to write (newbie programmer here) doesn't seem to work. I looked at the reference library on the Arduino website too.
Robots are cool.
UK
That's sad.
(Hint)
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Robots are cool.
UK
OK, so what does it do that it shouldn't and what doesn't it do that it should?
Code tags would be good too.
It doesn't move at all when I upload it.
Robots are cool.
Pages: 1 ... 5 6 [7] 8 9   Go Up
