Pages: [1] 2   Go Down
Author Topic: Measuring speed of falling object  (Read 674 times)
My son has to do a science project for 6th grade.  We are thinking about dropping weighted ping pong balls from about a 6 six story height.  We would measure how fast each ball fell.  (air resistance would cause the lighter balls to fall slower).
Any ideas on how we could time the ball drop?
I am thinking about using two arduinos.  One would be at the top.  The ball would fall through a tube and I would use a photo sensor to detect when the ball dropped.  The top arduino would then fire a laser pointer to signal the bottom arduino to start a timer clock.  The bottom arduino would have an accelerometer attached to a table.  When the ball lands on the table, the accelerometer senses the impact and stops the clock.  I then have the start/stop time sent back to my laptop.
Anyone think this would work or have a better idea?  Would an accelerometer be able to sense this type of thing?
thanks
chad
SE USA
@ssh0le
use one arduino cause they are more than capible and 2 optical sensors at the bottom
so one arduino, one trigger switch at the top, two "magic eyes" at the bottom for each tube and your done
Johannesburg UTC+2
Hmmmm you could probably use one Arduino with two microswitches like these to stop and start the clock.
But by measuring the time, you're not going to measure the speed as such... you'll have to infer the speed from the Equations of Motion in which you would need to assume a value of g. (Or measure g in another experiment, like measuring the period of a pendulum.)
(Bit unclear as to your objective... your subject says speed, but your opening para says how fast it fell, which could be just the elapsed time? Time's one thing, measuring the terminal velocity is another)
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
His teacher wants him to do a repeatable experiment and show effects of changing one variable.  So we want to show that changing the wait, changes how long it takes the ball to fall a specific distance.  So not really needing to measure the speed, just the time to fall over a specific distance.
The last thing you did is where you should start looking.
You might be able to use a sound sensor to detect when the ball hits the ground/table/etc.
http://www.dfrobot.com/wiki/index.php?title=Analog_Sound_Sensor_%28SKU:_DFR0034%29
Johannesburg UTC+2
Well in theory, changing the weight (which is what you meant I guess  smiley-cool ) won't change the time, although with "floaty" objects it might.
Here's a much simpler experiment and involves nothing but the stop watch on your cellphone. Set up a simple pendulum, and show that the mass doesn't affect the time of the swing, only the length does.
Edit.... and while you're at it, verify that T = 2 pi (l / g)1/2 or conversely rearrange and use it as a means of showing what g is
« Last Edit: January 07, 2013, 03:10:33 am by JimboZA » Logged
IT Crowd:
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Go with Osgeld's idea, because not only can that way calculate fall time, but it can calculate the speed as well. The only downside is that you need to keep the PP ball within a decent range of the sensors, otherwise the data will be off.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Leighton Buzzard, UK
wind may be a major factor here
hitting the target from more than a few feet may be nigh on impossible
there are only 10 types of people
them that understands binary
and them that doesn't
Montreal
Online Online
Per aspera ad astra.
If only average speed has to be determined, know height and time, only time should be measured accurately. I'd put arduino (smallest one?) inside a ball,  with two buttons, one to be released by operator when dropping a ball, second one 'd be pressed automatically at falling time ( feather tail would sure ball always fall on the same side).
Boston area, metrowest
I would think a wireless message from top to bottom would be easier to implement.
RF travels at speed of light too.
The easiset way is a good camcorder and video tape it. If you use DV you can get 1/30th second resolution.
Left Coast, CA (USA)
Measurement changes behavior
No it wouldn't. The air resistance would be the same for a same size ping pong ball no matter what weight difference. Didn't Sir Isaac Newton already demonstrate that weight is not a factor in a falling object?
Sure, optical sensors/emitters on the outside of a plastic tube or pipe that has a ID diameter just a little larger then a ping pong ball that is 'looking through' the pipe, using one sensor/emitter at near the top of the tube and one near the bottom of the tube. Arduino would time interval between start and stop, speed is just a math equation based on that elapsed speed.
Lefty
« Last Edit: January 07, 2013, 11:30:13 am by retrolefty » Logged
Milton Keynes UK
No it wouldn't. The air resistance would be the same for a same size ping pong ball no matter what weight difference. Didn't Sir Isaac Newton demonstrate that weight is not a factor in a falling object?
I'm very surprised to see that from you retrolefty. Sir Isaac Newton's experiment only works when the effects of air resistance can be ignored. If you drop a feather and a cannon ball, the feather falls more slowly.
If the balls are being dropped through a pipe that is anywhere near the size of the balls then the aerodynamic blockage will cause a much higher drag than you'd seen in fresh air. This would have a much greater effect on very light balls such as a ping pong ball. You may also see mechanical drag if the balls start bouncing off the sides of the tube.
« Last Edit: January 07, 2013, 11:34:46 am by PeterH » Logged
Well I'm very surprised at you, don't two ping pong balls have the same wind resistance even if one is hollow and the other filled with water? Read the actual experiment the OP is proposing.
Lefty
Montreal
Online Online
It's not correct, air resistance/drag  also depends on speed,
Pages: [1] 2   Go Up
