Loading...
Pages: [1]   Go Down
Author Topic: Program on/of motor dc??  (Read 248 times)
Indonesia
Offline Offline
Newbie
View Profile
is it same the program if i want to stop and run motor dc with LED blink ???
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Yes, but with different hardware.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Indonesia
Offline Offline
Newbie
View Profile
what you meant hardware ? component ?
can u tell me what the component i need ?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Yes.
Quote
Without more detail, no I can't.
Logged
Indonesia
Offline Offline
Newbie
View Profile
i'm just for spinning motor on/off ... im using 12vdc (2400)rpm..
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
My son's slot cars have 12 volt motors.
My diesel car has a 12 volt starter motor.
Your move.
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
So what are you using to drive that? This means what are you using to make the 5V signal from the arduino into a 12V signal for your motor?
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
You need something like this, where the pin D6 (or whatever pin you used for Blink) is switching the transistor on and off in the same way it was switching the LED for you. The transistor in turns lets or refuses the connection V to ground through the motor which therefore goes on and off.
Don't forget the diode across the motor connected as shown.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Pages: [1]   Go Up
Print
Jump to:
