Topic: YATC - Yet Another Terrarium Controller (Read 14457 times) previous topic - next topic
volshebnick
Hi there.
I think you also need a great enclosure to fit your arduino, buttons, lcd, etc.
Take a look at this topic: http://arduino.cc/forum/index.php/topic,141660.0.html
Let me know if you decided to get one, we will customize size and cut needed windows for you. I think a cherry wooden one will look pretty nice with terrarium.
wildbill
These names are a clue that you can refactor: TemperatureControlT1, TemperatureControlT2. Consider making these a single function and pass the specific terrarium parameters, either as individual arguments or as a struct (or pointer to one) so that the same code can serve many terrarium instances. Alternatively, you could go full OO and just build a class that controls a terrarium - never thought I'd use that word so many times in a single post  ;)
dafes
#17
Feb 06, 2013, 10:40 pm Last Edit: Feb 06, 2013, 10:47 pm by dafes Reason: 1
Yes i thought about it. I thought also about a Struct Terrarium object with its Sensors. In the first step i want to build it as simple as possible to get the job done :)
I have replaced the RTC with an GPS Clock and added some additional "timers"
long Seconds30Interval = 30000;  //30 Secons //Intervall in miliseconds
long previous30SecondsMillis = 0;        // will store last time CheckForSomethingtoDo was running
long Minute1Interval = 60000;  //1min //Intervall in miliseconds
long previous1MinuteMillis = 0;        // will store last time CheckForSomethingtoDo was running
long Minute5Interval = 300000;  //5min //Intervall in miliseconds
long previous5MinuteMillis = 0;        // will store last time CheckForSomethingtoDo was running
long Hour1Interval = 3600000;  //1hour //Intervall in miliseconds
long previous1HourMillis = 0;        // will store last time CheckForSomethingtoDo was running
This will give mne some freedom.
At the moment i stuck at the Day Night things:
I created a function which Adjusts the DayNightRhythm according the month:
void SetDayRhythm_T2()
  if(GPS.month == 0){
    if(DEBUG) {Serial.println("Debug:SetDayRhythm_T2 GPS.month == 0");}
    return;
  if(DEBUG) {Serial.print("DEBUG: SetDayRhythm_T2 Month:");Serial.println(GPS.month,DEC); }
  switch(GPS.month)
    case 1:
      T2_DayStart = 915; //09:15
      T2_DayEnd = 2015; //20:15
      T2_SpotStart = 140; //14:00
      T2_SpotEnd = 200; //20:00
    break;
    case 12:
      T2_DayStart = 100; //10:00
      T2_DayEnd = 200; //20:15
      T2_SpotStart = 1600; //16:00
      T2_SpotEnd = 1700; //17:00
    break;
This is a litle dirty but it does the job. In the 30seconds function i got an Verify if its time to Start/Stop a Lamp or Spot
void _CheckForSomethingtoDoTerrarium1_30Seconds()
  String time = String(GPS.hour)+=String(GPS.minute);
  if(DEBUG) {Serial.println("Debug: _CheckForSomethingtoDoTerrarium1_30Seconds Time: ");Serial.println(time);  }
  if(time == String(T2_DayStart))
    if(DEBUG) {Serial.print("Debug: T2_DayStart Time: ");Serial.println(time);  }
    return;
  if(time == String(T2_DayEnd))
    if(DEBUG) {Serial.println("Debug: T2_DayEnd Time: ");Serial.println(time); }
    return;
  if(time == String(T2_SpotStart))
    if(DEBUG) {Serial.println("Debug: T2_SpotStart Time: ");Serial.println(time);  }
    return;
  if(time == String(T2_SpotEnd))
    if(DEBUG) {Serial.println("Debug: T2_SpotEnd Time: ");Serial.println(time);  }
    return;
Yes i use strings.. i will replace them a soon as possible :) this is just a habit from c#.
Anyway has anybody a solution for a dynamic Terrarium struct which includes a "array" or "list" of sensors(a sensor is an 8 byte array)
byte sensor1[8] = { 0x10, 0xB2, 0xA0, 0x54, 0x2, 0x8, 0x0, 0x4E };
How can i walk thorugh such a array of sensors?
Edit: Is the String Problem still present? I have read some post that this was prior 1.0:
http://code.google.com/p/arduino/issues/detail?id=468&q=string&sort=-id
http://stackoverflow.com/questions/12930978/array-of-strings-char-array-in-c-arduino-how-do-i-accomplish-it
dafes
I have two Terrariums so i need a Modular Controller to inependently Controll both.
Why not two UNO's in stead of one MEGA?  Modular is modular ;)
and simulate Sun Rising/ Falling
I discussed an algorithm here - http://arduino.cc/forum/index.php/topic,66426.0.html - might be useful
(you can also connect an LDR to the window and "read the local sunset/rise" :)
i have read the Post and created a function according to this Post. the Location is Sydney (Because of UpsideDown i switched December with June to match the local Time.
Lat:
-33,52,0
Long:
-151,13,0
Sunries @23 June = 7:00 = 60 * 7 + 0 =420
Sunrise @23 dec = 4:42 = 60*4 + 42 = = 282
average = (=420+282)/2 = 351
delta = =420- 282= 138 => divide by 2 makes 69
Sunset @23 Dec 7:06PM = 60 * 19 + 6 = 1146
Sunset @23 June 4:54PM = 60*16 + 54 = 1014
average = (1146+1014)/2 = 1080
delta = 1146 - 1014= 132 => divide by 2 makes 66
void getRiseSet()
  float common = 69 * cos( ((month-1)*30.5+dayOfMonth + 8 ) * 0.017214206) ;  // replace division with faster multiplication
  sunrise = 351 + common;
  sunset = 1080 - common;
robtillaart
Formula looks good.
Run it in a loop from day 1 to day 365 and check it against some website: - http://www.timeanddate.com/worldclock/astronomy.html?n=240 -
Rob Tillaart
benoitchampougny
salut a tous,
Je suis a la recherche de développeur pour un projet opensource similaire, Nous somme déjà 3 sur ce projet.
Ce projet consiste a rendre accessible aux plus novices les fonctionnalités du rapberry pi et arduino combinés dans le but de gérer des systêmes domotiques annexes tel qu'une ruche, un jardin, un aquarium, une cave a vin, une champignonnière, un terrarium, une serre, enfin presque tout enfaite.
Une interface graphique seras accessible depuis partout. Un systême de scénarios configurable permettra la régulation ainsi que l'alerte mail et sms du systême.
Le But étant de pouvoir partager depuis un site communautaire des données créer par la communauté dans un esprit de DRY (don't repeat yourself), pour éviter que chacun écrive sont petit morceau de code dans sont coin alors qu'il pourrais le rendre accessible a toute une communauté. Quel gains de temps pour toute une communauté!!!.
n'hésitez pas à nous rejoindre, on ne mort pas lol!!! les projets open sources ont besoin de vous!!
https://ardui-farm.sonetin.com/
