Topic: Can't compile/build recent GIT 1.5.x IDE (Read 1 time) previous topic - next topic
baltasar
Hi, don't know what started hapenning but after a few last git pull updates I can´t build anymore the IDE.
I allways get this error:
test:
    [mkdir] Created dir: D:\Git Projects\Arduino\app\test-bin
    [javac] Compiling 2 source files to D:\Git Projects\Arduino\app\test-bin
    [javac] warning: [options] bootstrap class path not set in conjunction with -source 1.5
    [javac] 1 warning
     [copy] Copying 5 files to D:\Git Projects\Arduino\app\test-bin
     [copy] Copying D:\Git Projects\Arduino\app\test\Keypad_mac.zip to D:\Git Projects\Arduino\app\t
est-bin\Keypad_mac.zip
     [copy] Copying D:\Git Projects\Arduino\app\test\Keypad_with_hidden_files.zip to D:\Git Projects
\Arduino\app\test-bin\Keypad_with_hidden_files.zip
     [copy] Copying D:\Git Projects\Arduino\app\test\Test.zip to D:\Git Projects\Arduino\app\test-bi
n\Test.zip
     [copy] Copying D:\Git Projects\Arduino\app\test\Test2.zip to D:\Git Projects\Arduino\app\test-b
in\Test2.zip
     [copy] Copying D:\Git Projects\Arduino\app\test\processing\app\tools\test_partial_boards.txt to
D:\Git Projects\Arduino\app\test-bin\processing\app\tools\test_partial_boards.txt
    [junit] Running processing.app.tools.MapWithSubkeysTest
    [junit] Tests run: 1, Failures: 0, Errors: 0, Time elapsed: 0.188 sec
    [junit] Running processing.app.tools.ZipDeflaterTest
    [junit] Tests run: 4, Failures: 0, Errors: 4, Time elapsed: 0.203 sec
BUILD FAILED
D:\Git Projects\Arduino\build\build.xml:35: The following error occurred while executing this line:
D:\Git Projects\Arduino\build\build.xml:68: The following error occurred while executing this line:
D:\Git Projects\Arduino\app\build.xml:79: Test processing.app.tools.ZipDeflaterTest failed
Anyone facing this problem? Solutions?
Thanks.
Hi Baltasar!
This error occurs when the directory of your repository for the project has space.
Carlos Delfino.
cmaglie
baltasar,
for some reason the ZipDeflate test is failing. You can see the test result here:
app/test-bin/TEST-processing.app.tools.ZipDeflaterTest.xml
if you can copy & paste the content of this file here we can do some further analysis-.
C.
