Loading...
Pages: 1 [2]   Go Down
Author Topic: translating shifts from Java (Processing) to C++ (arduino)  (Read 484 times)
Offline Offline
Full Member
View Profile
Again, thanks. Especially using one char variable names makes it unnecessarily harder.
Logged
Des Moines, WA - USA
Offline Offline
God Member
View Profile
Code:
struct rgb_t
    union
        struct {
            unsigned r:5;
            unsigned g:6;
            unsigned b:5;
        uint16_t    rgb;
rgb_t   rgb = { 1, 2, 3 };
int     r   = rgb.r;
int     g   = rgb.g;
int     b   = rgb.b;
'rgb_t' is the same size as an 'unsigned int', or 'uint16_t, on the Arduino.
Code:
rgb_t   rgb;
rgb.rgb = rgbPacked;
int     r   = rgb.r;
int     g   = rgb.g;
int     b   = rgb.b;
Logged
Offline Offline
Full Member
View Profile
Thanks lloyddean .. but I don't quite understand the code you provided. Is this another way to decode the 2 byte RGB?
Thanks
Robert
Logged
Offline Offline
God Member
View Profile
Yes, but with a lot less work on your part in that you write less code.
Post your code and we'll go about getting to work the way you want.
Logged
Offline Offline
God Member
View Profile
Looking at a post in the 'Sensors' forum I saw you had posted some code.  Here is a reimplementation of a short section in your library code -
Code:
struct rgb_t
    union {
        struct {
            unsigned _b:5;
            unsigned _g:6;
            unsigned _r:5;
        uint16_t    _rgb;
    rgb_t(uint8_t r, uint8_t g, uint8_t b)
        : _r(r), _g(g), _b(b)
    rgb_t(uint16_t rgb)
        : _rgb(rgb)
    operator uint16_t() const { return _rgb; };
    uint8_t red()   const     { return _r;   };
    uint8_t green() const     { return _g;   };
    uint8_t blue()  const     { return _b;   };
uint32_t HacroCam::pixel(uint8_t r, uint8_t g, uint8_t b)
    return rgb_t(r >> 3, g >> 2, b >> 3);
byte HacroCam::lsb(byte r, byte g, byte b) {
    return lowByte(pixel(r, g, b));
byte HacroCam::msb(byte r, byte g, byte b) {
    return highByte(pixel(r, g, b));
« Last Edit: January 09, 2013, 11:06:27 pm by lloyddean » Logged
Offline Offline
God Member
View Profile
If I understand the basis of your original question you wish to convert a source pixel buffer of  'rrrrrggggggbbbbb' values to a gray scale equivalent destination pixel buffer.
The following code fragment should accomplish that ...
Code:
struct rgb_t
    union {
        struct {
            unsigned _b:5;
            unsigned _g:6;
            unsigned _r:5;
        uint16_t    _rgb;
    rgb_t(uint16_t rgb)
        : _rgb(rgb)
uint8_t bufSrc[32];    // color pixel buffer
uint8_t bufDst[32];    // gray scale buffer
// convert the color pixel buffer 'bufSrc' to an average gray scale pixel buffer 'bufDst'
rgb_t* pSrc = (rgb_t*)bufSrc;
rgb_t* pDst = (rgb_t*)bufDst;
for (uint16_t i = sizeof(bufSrc) / 2; i--; )
    rgb_t    pixelSrc = *pSrc++;
    uint8_t  average  = (pixelSrc.red() + (pixelSrc.green() >> 1) + pixelSrc.blue());
    *pDst++ = rgb_t(average, average << 1, average);
Logged
Offline Offline
Full Member
View Profile
You are correct. I try to converto 16 bit rgb to 8 bit and 4 bit grayscale.
Your code looks very clean. Creating a struct/class is really good, if reused often. Thanks for the input and example.
Do you expect your code to be more efficient or does the compiler translate my "beginner style" code to something equal?
Robert
Logged
Offline Offline
God Member
View Profile
The above example code is converting from 16-bit color to 16-bit gray scale.
What do you mean by converting to 8 bit and 4 bit grayscale.
rrrrrggggggbbbbb -> what 8-bit
rrrrrggggggbbbbb -> what 4-bit
Logged
Offline Offline
Full Member
View Profile
I mean:
16 bit RGB = 1 pixel per 2 byte -> RRRRRGGGGGGBBBBB
8 bit grayscale = 1 pixel per byte -> GGGGGGGG
                                                 pix1    pix2
4 bit grayscale = 2 pixel per byte -> GGGG GGGG
It's working with the code provided by robtillaart. Yours is more compat but also (for me) more complaex to read.
If it ismore efficient regarding storage space or calculation time, I will try to implement it.
Thanks
Robert
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
