Loading...
Pages: [1]   Go Down
Author Topic: C328 Serial Camera Library  (Read 825 times)
Offline Offline
Newbie
View Profile
Need help folks!, how can i make C328 Serial Camera Library work on Arduino IDE 1.0.3?
here are the errors:
Code:
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:24:22: error: WProgram.h: No such file or directory
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:25:24: error: WConstants.h: No such file or directory
In file included from jan4.ino:1:
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:120: error: expected `)' before '&' token
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:128: error: 'byte' has not been declared
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:130: error: 'byte' has not been declared
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:133: error: ISO C++ forbids declaration of 'SerialBase' with no type
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:133: error: expected ';' before '*' token
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:135: error: 'byte' does not name a type
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:136: error: 'byte' does not name a type
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:137: error: 'byte' has not been declared
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:137: error: ISO C++ forbids declaration of 'byte' with no type
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:139: error: 'byte' has not been declared
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:142: error: ISO C++ forbids declaration of 'byte' with no type
C:\arduino projects\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:143: error: ISO C++ forbids declaration of 'byte' with no type
but after changing the line
Code:
#include "WProgram.h"
into
Code:
#include "Arduino.h"
here are the errors
Code:
please see attached files for the library i've used, please help..thanks!
« Last Edit: January 07, 2013, 09:54:39 am by roja_winrox » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Remove WConstants.h. The contents are now part of Arduino.h.
Change NewSoftSerial to SoftwareSerial everywhere.
Logged
Offline Offline
Newbie
View Profile
thanks PaulS for your response!, I already remove the WConstants.h..
but can't find any NewSofSerial on CameraC328r.cpp and CameraC328r.H ?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Perhaps you should try NewSoftSerial, then:
Code:
class NewSoftSerial;
CameraC328R(NewSoftSerial *softSerial = NULL);
NewSoftSerial *_serialPort;
#include <NewSoftSerial.h>
CameraC328R::CameraC328R(NewSoftSerial *softSerial)
Logged
Manaoag
Offline Offline
Newbie
View Profile
this is also my problem in c328..i will post the code...
Code:
#include <SoftwareSerial.h>
#include <CameraC328R.h>
#define LED_PIN 13
#define PAGE_SIZE 64
#define USB_BAUD 115200
#define CAMERA_BAUD 14400
SoftwareSerial mySerial(2 , 3);
CameraC328R camera(mySerial);
uint16_t pictureSizeCount = 0;
* This callback is called EVERY time a JPEG data packet is received.
void getJPEGPicture_callback( uint16_t pictureSize, uint16_t packageSize,
uint16_t packageCount, byte* package )
// packageSize is the size of the picture part of the package
pictureSizeCount += packageSize;
Serial.write(package,packageSize);
if( pictureSizeCount >= pictureSize )
digitalWrite( LED_PIN, LOW );
Serial.flush();
Serial.begin( USB_BAUD );
mySerial.begin(CAMERA_BAUD);
pinMode( LED_PIN, OUTPUT );
if( Serial.available() ){
while(Serial.read() != -1);
digitalWrite( LED_PIN, HIGH );
if( !camera.sync() )
{Serial.println( "Sync failed." );
return ;
if( !camera.initial( CameraC328R::CT_JPEG, CameraC328R::PR_160x120,
CameraC328R::JR_640x480 ) )
Serial.println( "Initial failed." );
return ;
if( !camera.setPackageSize( 64 ) )
Serial.println( "Package size failed." );
return ;
if( !camera.setLightFrequency( CameraC328R::FT_50Hz ) )
Serial.println( "Light frequency failed." );
return ;
if( !camera.snapshot( CameraC328R::ST_COMPRESSED, 0 ) )
Serial.println( "Snapshot failed." );
return ;
if( !camera.getJPEGPicture( CameraC328R::PT_JPEG, PROCESS_DELAY,
&getJPEGPicture_callback ) )
Serial.println( "Get JPEG failed." );
return ;
Moderator edit: [code] [/code] tags added.
« Last Edit: January 17, 2013, 06:20:56 pm by Coding Badly » Logged
Manaoag
Offline Offline
Newbie
View Profile
please help me..i really need to correct this code.... smiley-confuse
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
One punctuation mark is sufficient.
What is wrong with the code? Why do you think it needs fixing.
We've hired a psychic, but Andre's start date is the 12th of never. If you need help before then, you need to define what help it is you need.
Logged
Manaoag
Offline Offline
Newbie
View Profile
i use the arduino 1.0.3...so why is it there is error if the code is correct...
here is the error...
In file included from serial_cam.ino:3:
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:26:20: error: wiring.h: No such file or directory
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:136: error: 'byte' has not been declared
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:142: error: 'byte' has not been declared
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:148: error: 'byte' does not name a type
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:149: error: 'byte' does not name a type
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:150: error: 'byte' has not been declared
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:150: error: ISO C++ forbids declaration of 'byte' with no type
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:152: error: 'byte' has not been declared
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:155: error: ISO C++ forbids declaration of 'byte' with no type
D:\arduino-1.0.3-windows\arduino-1.0.3\libraries\CameraC328R/CameraC328R.h:156: error: ISO C++ forbids declaration of 'byte' with no type
serial_cam.ino: In function 'void loop()':
serial_cam:65: error: invalid conversion from 'void (*)(uint16_t, uint16_t, uint16_t, byte*)' to 'void (*)(uint16_t, uint16_t, uint16_t, int*)'
serial_cam:65: error: initializing argument 3 of 'bool CameraC328R::getJPEGPicture(CameraC328R::PictureType, uint16_t, void (*)(uint16_t, uint16_t, uint16_t, int*))'
i really need to correct this code..please help me! smiley-cry
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Well, clearly the code is NOT correct. One punctuation mark is enough. More than that pisses people off. You want help, it's a good idea not to piss people off.
Quote
Do you have a wiring board? Are you using the Wiring IDE? I didn't think so. So, the library is not really intended for an Arduino.
You could, of course, change wiring.h to Arduino.h to get rid of that message. And, doing that will get rid of more of the messages.
Logged
Manaoag
Offline Offline
Newbie
View Profile
I'm sorry because i am only a newbie in arduino..and i am studying it yet..sorry for my english...could you please help to correct this code?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Maybe after you learn to use punctuation correctly.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
The code is almost verbatim from here... http://arduino.cc/forum/index.php/topic,123829.msg931454.html#msg931454
The solution to the compilation errors are very likely here... http://arduino.cc/forum/index.php/topic,123829.msg931546.html#msg931546
Logged
Pages: [1]   Go Up
Print
Jump to:
