Topic: sending data between 2 arduinos using xbee (Read 3518 times) previous topic - next topic
vima
I am having the following:
2 arduinos and 2 xbees. I want to send data from the one to another. The xbees communicate because I have the proposes test (connect one xbee with the arduino and the other to the PC, write from the one, watch the other in the other terminal).
Now I want to send data from the one to another:
These are my 2 scripts:
for sending: 9which is tested in the former test that sends all the letters)
Code: [Select]
    #include <SoftwareSerial.h>
    SoftwareSerial xbee(2, 3); // RX, TX
    char c = 'A';
    int  pingPong = 1;
     Serial.println( "Arduino started sending bytes via XBee" );
       // set the data rate for the SoftwareSerial port
       xbee.begin(9600);
    void loop()  {
      // send character via XBee to other XBee connected to Mac
      // via USB cable
      xbee.write( c );
      //--- display the character just sent on console ---
      Serial.println( c );
      //--- get the next letter in the alphabet, and reset to ---
      //--- 'A' once we have reached 'Z'.
      c = c + 1;
      if ( c>'Z' )
           c = 'A';
      //--- switch LED on Arduino board every character sent---
      if ( pingPong == 0 )
        digitalWrite(13, LOW);
        digitalWrite(13, HIGH);
      pingPong = 1 - pingPong;
      delay( 1000 );
Problem is when connected an arduino to receive data from the other XBee.
Here is my code:
Code: [Select]
     Serial.println( "Arduino started receiving bytes via XBee" );
       xbee.begin(9600);
    void loop()  {
     int temp=xbee.read();
     Serial.print("Character received:");
     Serial.println(temp);
Output is always:
Code: [Select]
Character received: -1.
If I change the temp from int to byte I see
Code: [Select]
Character received: (a non-ascii symbol)
PaulS
Quote
What kind of XBees? How are they configured?
Quote
With duct tape? HOW?
vima
XBee series 1.
they are configured through X-CTU, based on the one tutorial found on ladyada.net.
Then I connected XBee to arduino (TX to pin 3, RX to 2, vcc and gnd respectively) and the other XBee to pc through FTDI cable.
I was able to send characters from the arduino and see them in the serial monitof of the X-CTU. Does this mean that they are configured correclty?
Then I wanted to connect an arduino to my receiver. You can see the code above. I am always getting no available data.
Returned -1 means that there is no data in the serial.
PaulS
Quote
What is supposed to be sending serial data to the Arduino?
If one XBee is on the Arduino, and the other is on the USB Explorer connected to the PC, what, on the PC is sending data?
vima
Both XBees are connected to different arduino.
the one does xbee.write() where xbee is a new software serial
and the other one does xbee.read().
XBees are correclty configured since I tested it (I think I done it correctly).
I am missing something, though.
PaulS
Quote
Configured how? What did you set/change?
You should have set PAN ID, MY, and DL. What values does each one have?
vima
If they are working with FTDI, doesn't that mean that they are working correclty?
I have seet PAN ID of both to 2001.
also set ATDH to be the common high bits of xbee.
And ATDL is the bottom bits of the destination. Since A wants to send to B, ATDL of A has the bottom bits of B and vice versa.
PaulS
Quote
Usually. But I have no problems communicating when I set PAN ID, MY, and DL.
Post screen shots of X-CTU showing how you have configured both XBees.
vima
Can you help me on what is MY? DL is the destination Low bits right?
PaulS
Quote
Yes.
Quote
Have you even fired up X-CTU?
draythomp
I took a quick look at the receiving XBee code and it appears that you read a character in a loop without checking to see if there is a character there to read.  You need to put a
if (xbee.available){
     whatevervariable = xbee.read;
in there.  See, there are no characters available so read returns a -1 and you get the error you're seeing.
Or, did I miss something obvious?
Trying to keep my house under control http://www.desert-home.com/
vima
Quote
Yes.
Quote
Yes I had. But so far I had configured DL,DH, and PAN ID. And I told you through FTDI it plays.
So can you help me on that? What MY stands for?
PaulS
Quote
What MY stands for?
It does not stand for anything. MY is the name (numeric value only) of the XBee. It is the value that the other XBee uses as DL.
sams99
sorry.. i want to ask..
how to print data ony without print the acknowledgment between xbee s2 in API mode???
plese help me,,,thx very much
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
