Author Topic: sending data between 2 arduinos using xbee  (Read 301 times)
I am having the following:
2 arduinos and 2 xbees. I want to send data from the one to another. The xbees communicate because I have the proposes test (connect one xbee with the arduino and the other to the PC, write from the one, watch the other in the other terminal).
Now I want to send data from the one to another:
These are my 2 scripts:
for sending: 9which is tested in the former test that sends all the letters)
    #include <SoftwareSerial.h>
    SoftwareSerial xbee(2, 3); // RX, TX
    char c = 'A';
    int  pingPong = 1;
     Serial.println( "Arduino started sending bytes via XBee" );
       // set the data rate for the SoftwareSerial port
       xbee.begin(9600);
    void loop()  {
      // send character via XBee to other XBee connected to Mac
      // via USB cable
      xbee.write( c );
      //--- display the character just sent on console ---
      Serial.println( c );
      //--- get the next letter in the alphabet, and reset to ---
      //--- 'A' once we have reached 'Z'.
      c = c + 1;
      if ( c>'Z' )
           c = 'A';
      //--- switch LED on Arduino board every character sent---
      if ( pingPong == 0 )
        digitalWrite(13, LOW);
        digitalWrite(13, HIGH);
      pingPong = 1 - pingPong;
      delay( 1000 );
Problem is when connected an arduino to receive data from the other XBee.
Here is my code:
     Serial.println( "Arduino started receiving bytes via XBee" );
       xbee.begin(9600);
    void loop()  {
     int temp=xbee.read();
     Serial.print("Character received:");
     Serial.println(temp);
Output is always:
Character received: -1.
If I change the temp from int to byte I see
Character received: (a non-ascii symbol)
Seattle, WA USA
Online Online
Seattle, WA USA
What kind of XBees? How are they configured?
With duct tape? HOW?
XBee series 1.
they are configured through X-CTU, based on the one tutorial found on ladyada.net.
Then I connected XBee to arduino (TX to pin 3, RX to 2, vcc and gnd respectively) and the other XBee to pc through FTDI cable.
I was able to send characters from the arduino and see them in the serial monitof of the X-CTU. Does this mean that they are configured correclty?
Then I wanted to connect an arduino to my receiver. You can see the code above. I am always getting no available data.
Returned -1 means that there is no data in the serial.
Seattle, WA USA
Online Online
Seattle, WA USA
What is supposed to be sending serial data to the Arduino?
If one XBee is on the Arduino, and the other is on the USB Explorer connected to the PC, what, on the PC is sending data?
Both XBees are connected to different arduino.
the one does xbee.write() where xbee is a new software serial
and the other one does xbee.read().
XBees are correclty configured since I tested it (I think I done it correctly).
I am missing something, though.
Seattle, WA USA
Online Online
Seattle, WA USA
Configured how? What did you set/change?
You should have set PAN ID, MY, and DL. What values does each one have?
If they are working with FTDI, doesn't that mean that they are working correclty?
I have seet PAN ID of both to 2001.
also set ATDH to be the common high bits of xbee.
And ATDL is the bottom bits of the destination. Since A wants to send to B, ATDL of A has the bottom bits of B and vice versa.
Seattle, WA USA
Online Online
Seattle, WA USA
Usually. But I have no problems communicating when I set PAN ID, MY, and DL.
Post screen shots of X-CTU showing how you have configured both XBees.
Can you help me on what is MY? DL is the destination Low bits right?
Seattle, WA USA
Online Online
Seattle, WA USA
Yes.
Have you even fired up X-CTU?
New River, Arizona
I took a quick look at the receiving XBee code and it appears that you read a character in a loop without checking to see if there is a character there to read.  You need to put a
if (xbee.available){
     whatevervariable = xbee.read;
in there.  See, there are no characters available so read returns a -1 and you get the error you're seeing.
Or, did I miss something obvious?
Trying to keep my house under control http://www.desert-home.com/
Yes.
Yes I had. But so far I had configured DL,DH, and PAN ID. And I told you through FTDI it plays.
 So can you help me on that? What MY stands for?
Seattle, WA USA
Online Online
Seattle, WA USA
What MY stands for?
It does not stand for anything. MY is the name (numeric value only) of the XBee. It is the value that the other XBee uses as DL.
