Topic: enumeration declaration (Read 5119 times) previous topic - next topic
kyrpav
i have this
enum food{orange,apple,pineapple,watermelon} fruits;
void choosefood(char setfood[]){
fruits=setfood;
switch (fruits):
And this does not work because
cannot convert 'char*' to food enum
basically what i want to do is call a function and give a string. Inside  the function i want to set the string to the value of the enum food fruits.
in general
food fruits=orange;
works but i want to be able to set a string without typing the word exactly something like a reference. I could retrieve the string from another function and give it to this so i wont have manual interference.
tobyb121
Can you just explain this a bit better, do you want a function that you call like: chooseFood("orange") which sets the value fruits to orange (from your enum). If so the only way I think you are going to be able to that is to have a series of if statements with comparing the string values, either with strcmp or your own fuction.
KeithRB
Even though the enums are assigned sequentially, you could do something like this:
char * fruitstrings[6];
/* This part must be in a function! */
fruitstrings[orange] = "orange";
fruitstrings[apple] = "apple";
KeithRB
You might also look into the "stringizing" operator # and create a macro like:
#define enum_string(en) #en
Used like this: enum_string(orange)
kyrpav
well i think you got it. I want to call a function that will give me a string. after that i want to set the string equal to the value of an enumerated variable. I am sure that the string is one of the values.
So one function will give a string that could be "orange ,watermelon, apple" something of theses but i do not know which of them. everyday it would be different.
And i want to have a second function which will do thing. the first thing i want it to do is to set the the string as the value of the enumerated variable like you said
if the string is :
string mystring = "apple";
then
it will do
food fruits= apple;
but i do not know which  the string will be every day so i need this to be updated.
pYro_65
Enums are for ranges, what you have is a discrete set of values.
You are better off having a collection of strings in progmem that you can compare against, your key or index ( what would be the enum value ) is simply the index of the corresponding progmem string.
The error you had here:
fruits=setfood;
is because 'setfood' is a pointer, a 16-bit value that has nothing to do with the data it points to. The other problem here is on initialisation the enum can happily be set to values outside the range you specified. This is because the valid enum range is more than what is specified in the brackets.
Forum Mod anyone?
https://arduino.land/Moduino/
kyrpav
i understand that there is a way to do my job with strings and nested ifs.
regardless what i want to do can you give me  a solution to the problem i will make more specific.
i have a string
char x[]="orange";
i do not know whati s written in the string but i know that it is enumerated in the values of an enumerated variable.i am sure of it.
so the variable is
enum food{orange,apple,watermellon} fruits;
how can i set fruits=orange
with out typing this exactly but by using the char x[].
fruits=x;
fruits = *x;
does not work i undestand it. But how can i manage it?
johncc
I think this is about as close as you're gonna get:
enum food { orange, apple, watermelon };
food foodbar(const char * x){
if ( !strcmp(x, "orange")) return orange;
if ( !strcmp(x, "apple")) return apple;
if ( !strcmp(x, "watermelon")) return watermelon;
void setup(){
food fruits=foodbar("apple");
kyrpav
#8
Jan 08, 2013, 12:18 am Last Edit: Jan 08, 2013, 12:23 am by kyrpav Reason: 1
ok thank you i have one more question. eclipse understands that function foodbar belongs to datatype  food and it is a non-void function , and foodbar returns something but eclipse does not understand it and it gives warning.
PeterH
It works in that example, but IMO it's bad practice to treat the return value from strcmp() as a boolean since it isn't one. I'd much rather see an explicit comparison with zero. (Apart from that quibble, I think you've described the simplest and most straight forward implementation.)
PaulS
Then it (or you) understand it all wrong. The function is declared to return a value of type food, which is an enum.
but foodbar returns something so it makes a warning.
Then, eclipse is wrong. Specifically, what warning?
also you could say that the foodbar functions returns a food variable
Again, you'd be wrong. It returns a value of type food, not a variable of type food. What you do with that value is up to you. You can store it in a variable of type food, or print it, or pass it to a function that expects a food.
kyrpav
yes thank you and sorry about my english i meant that it returns a value of type food. and i do not get why it give warning:
Description   Resource   Path   Location   Type
No return, in function returning non-void   main.cpp /testing/src   line 22   Code Analysis Problem
johncc
Eclipse is complaining because I should have written something more like:
enum food { orange, apple, watermelon, unknown };
return unknown;
PaulS
means that not all paths properly return a value. You need to add another value, None, to the enum and return that at the end of the function, if no other return path is followed.
kyrpav
and this was because you did not have else at the last if? this is like a default situation in switch() i think.
