Loading...
Pages: [1]   Go Down
Author Topic: Problem with teensy  (Read 300 times)
Offline Offline
Newbie
View Profile
Hi, I'm currently working on a teensy based (game)controller, but i have some problems:
My projects just keeps spitting out random letters forever, whenever i push a button (the point is it should spit out one specific letter at a time).
I have tested my circut pretty well, and can't seem to find my flaw in there, but would you maybe take a look at me (relatively short) to see if the mistake is in there? http://pastebin.com/wjvQB2HT
or could multiple wires close together interfere with each other (sorry, i'm not a smart man..)
Logged
Valencia, Spain
Offline Offline
Faraday Member
View Profile
try this:
Code:
  for(int i = 0; i < 4; i++)
    pinMode(pins[i], INPUT);
   digitalWrite(pins[i], HIGH);
The digialWrite enables a pull up resistor on the input. Without it the pin will be floating around picking up the local radio station or the neighbor's microwave oven.
Logged
No, I don't answer questions sent in private messages...
Offline Offline
Newbie
View Profile
I'm already using a pull-down resistor, so there shouldn't be any problem there.
Logged
Brisbane, Australia
Online Online
God Member
View Profile
When you say random letters, I take that to mean you're getting lots of output outside of the 4 values in the array which gave me an idea.  Does having
Code:
Keyboard.begin();
in setup() make a difference?  I don't have a Teensy nor Leonardo to test this with, so I created a small sketch that calls Serial.print without a Serial.begin call and found it compiled but didn't produce output either.
Stabbing blindly in the dark and hoping for the best,
Geoff
Logged
Offline Offline
Sr. Member
View Profile
In case you are not aware, the teensy boards have their own support forum at
http://forum.pjrc.com
Logged
Pages: [1]   Go Up
Print
Jump to:
