Loading...
Pages: [1]   Go Down
Author Topic: Documentation correction  (Read 611 times)
Offline Offline
Newbie
View Profile
http://arduino.cc/en/Reference/BooleanVariables
in the last row the semicolon is missing
  if (digitalRead(switchPin) == LOW)
  {  // switch is pressed - pullup keeps pin high normally
    delay(100);                        // delay to debounce switch
    running = !running;                // toggle running variable
    digitalWrite(LEDpin, running)      // indicate via LED
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Yes. Unfortunately we moderators do not have privileges to correct those things.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Tennessee
Offline Offline
Newbie
Steak and Taters
View Profile
But.....this is where the suggestions link from the examples point. "Corrections, suggestions, and new documentation should be posted to the Forum."
 smiley-razz
Along those lines,
Clarification could be added to:
http://arduino.cc/en/Reference/AttachInterrupt
It mentions that the Due calls the interrupt pins differently, but doesn't specify which board the example code is written for.  Do you use "int.0" for the "interrupt" argument of the attachInterrupt function on the boards other than the Due?  Or would just "0" be acceptable for either?  (using the pin 0 on the Due, and pin 2 on the others)
« Last Edit: January 11, 2013, 12:33:14 am by djscurge » Logged
"Shall I refuse my dinner because I do not fully understand the process of digestion?"
-Oliver Heaviside
Pages: [1]   Go Up
Print
Jump to:
