Topic: Trouble with the SoftwareSerail.h in Arduino 1.03 (Read 6105 times) previous topic - next topic
Hovic
Jan 08, 2013, 01:51 am Last Edit: Jan 08, 2013, 02:37 am by Hovic Reason: 1
I'm getting an error that says that  PCMSK and PCICR is not declare in scope of SoftwareSerial.cpp lines 399-403 and lines 417-418
this is code that the arduino compiler point me too  in the cpp file
if (digitalPinToPCICR(_receivePin))
          *digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
          *digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin));
if (digitalPinToPCMSK(_receivePin))
             *digitalPinToPCMSK(_receivePin) &= ~_BV(digitalPinToPCMSKbit(_receivePin));
Can anyone please help me fix this error? I get this error with the example that came with the Arduino 1.03 software.
Coding Badly
Hovic
I try softwareSerialExample on different computer and had no problems.
Even thou i redownload the program on my computer that has the problems, there was no change in error
Coding Badly
In which case you need to remove[font=Courier New] SoftwareSerial [/font]from the[font=Courier New] {SketchRoot}/libraries/ [/font]folder.
Hovic
#4
Jan 08, 2013, 04:51 am Last Edit: Jan 08, 2013, 04:54 am by Hovic Reason: 1
the problem started with the arduino 1.02.   but
is it possible that old arduino 1.02 corrupt the SoftwareSerial.h in the updated version arduino 1.03?
Coding Badly
Did you remove[font=Courier New] SoftwareSerial [/font]from the[font=Courier New] {SketchRoot}/libraries/ [/font]folder?
Hovic
I remove the softwareSerial.h from the libraries, So what should i do now?
Coding Badly
Describe what happens when you try to compile the test program.
Hovic
if i remove it SoftwareSerial.h from libraries the sketch say that  SoftwareSerial.h is no such file or in directory.
#include "SoftwareSerial.h"
void setup(){}
void loop(){}
"sketch_jan08a.ino:1:28: error: SoftwareSerial.h: No such file or directory"
if i comment out the #include <SoftwareSerial.h> in the example SoftwareSerialExample. it says myserial not declared in scope.
Hovic
here all the errors that the compiler is showing me.
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:399: error: 'PCICR' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK2' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK0' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK1' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::end()':
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK2' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK0' was not declared in this scope
C:\Users\Peter C Cole\Documents\Arduino Program\arduino-1.0.3\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK1' was not declared in this scope
Coding Badly
I guess it's time to start over.  Maybe this time you'll answer my questions.
Board (or processor)?
Hovic
#11
Jan 08, 2013, 07:00 am Last Edit: Jan 08, 2013, 07:03 am by Hovic Reason: 1
arduino uno atmega 328p, this computer has intel core 2 duo processor
Coding Badly
The [font=Courier New] {SketchRoot} [/font]folder is where your sketches are stored.  The [font=Courier New] {SketchRoot} [/font]folder is not the[font=Courier New] arduino-1.0.3 [/font]folder.  I assume you did not delete the [font=Courier New] {SketchRoot}/libraries/SoftwareSerial/ [/font] folder.  Obviously you did delete the [font=Courier New] arduino-1.0.3/libraries/SoftwareSerial/ [/font]folder.  You will have to reinstall the Arduino IDE.
Hovic
#13
Jan 08, 2013, 07:43 am Last Edit: Jan 08, 2013, 07:51 am by Hovic Reason: 1
Where is the SketchRoot?
can you give a screen shot what you mean?
retrolefty
#14
Jan 08, 2013, 08:05 am Last Edit: Jan 08, 2013, 08:08 am by retrolefty Reason: 1
It is the folder name on your PC of where ever your sketches are saved to when you quit the IDE. The full path name is shown in the arduino IDE under files/Preferences,  in the top window named Sketchbook location. My path sketch folder is named   C:\Documents and Settings\Primary Windows User\My Documents\Arduino  when using arduino version 22 and it's path sketch folder name is C:\Documents and Settings\Primary Windows User\My Documents\Arduino\Arduino1 when I'm using arduino version 1.0.3.
This is the folder name where you can create a folder named libraries where you can then install 3rd party library files and example sketches for the library. The arduino core also has a folder named libraries that it populates with the 'official' arduino library files that come with IDE installation distrubution. You should not add or erase files in that folder, just your arduino users sketchbook folder/libraries folder.
Lefty
