Topic: Due IDE 1.5.1r2 crashes on startup, Windows XP SP3, 32-Bit (Read 2758 times) previous topic - next topic
cappy2112
Is anyone else having a problem running the beta version of Due IDE 1.5.1r2?
When I launch it on Windows XP SP3, 32-Bit the splash screen is displayed for quite a while, but then
"Launch4J
An error occurred while starting the application"
is displayed.
I've successfully installed the USB driver.
codlink
If you have Bluetooth enabled, disable it.  This is the most common issue with your error.
//LiNK
cappy2112
I don't have any bluetooth HW on that system
KurtE
I just installed this build and got this error as well on a Windows 7 64 bit machine.  (Just received my DUE today :) )
So I experimented some, and I went into my Arduino Sketchbook directory and renamed my Hardware directory to some other name and now it runs.
My hardware directory contains stuff to run for Arbotix Robots on an Atmega644p processor...
So if you have a Hardware directory try removing it and see if that helps.
Kurt
cappy2112
Kurt
Will try that- thanks.
How do we get this reported to the developers?
